These are not Arduino devices - at all. They may have Arduino headers which are mostly pin compatible with Arduino shields but they are not intended for use in Arduino IDE. They are programmed with Visual Studio under Windows.
You can use it once programmed under OSX but your code will need to leverage CDC mode
I have been doing .NETMF development for several years using Windows VMs and Fusion. In the past, some boards worked under VMs and other did not. I have not done any recent tests. The Panda II, last time I checked, did work with a VM.
I purchased a $300 PC from Dell and use it as my development machine. I run it headless, and use Remote Desktop on an IMac to connect to the PC. Easier that using a VM.
There does not seem to be a lot of members of the forum using Macs.
As part of the Scratch work, I created a Scratch Gateway, which handles deployment and the proxying of Scratch firmata-protocol commands over a serial port (either a second port, or the primary port in CDC mode).
In order to try to support this on Mac and Linux, (esp the Mac wrt educational settings) I ported the relevant Debug and MFDeploy libraries to Mono. A mono project will be part of the source drop for Scratch4.net, though it is in rough shape now and the Mac/Linux gateway will lag the windows version by some weeks. What this means is that yes, it is possible to deploy to (and of course, do serial interop with) NETMF devices from non-Windows hosts.
in THEORY, one could port the .net portions of the NETMF sources to mono, since mono compiler can target .net 2.0 and will emit the same IL code. You could then use the mono compiler to emit NETMF code and use my ported version of MFDeploy to deploy those. I have NOT tried this - it is a way bigger project than I care to take on now. The blue board fellow took this on in 2010 and never went beyond the initial checkin as near as I can tell, but I don;t know if that means he got dead ended or just bored.
Note to original poster : this doesn’t help you. You can get a netmf device to talk to OSX, but all of the above is either work in progress or just theoretical and it is not currently possible to program for NETMF anywhere but on Windows.
