Since upgrading to 4.3, I haven’t been able to get the ENC28 to function correctly on my Raptor board. It used to work, and now it doesn’t. I’ve look all over for answers and tried many different things.
I’m trying to call a web service from the FEZ Raptor board to write values to a DB.
I can get an IP Address and I can ping it, but communicating out from the board doesn’t work (when it did before).
I have NetworkChange_NetworkAvailabilityChanged and NetworkAddressChanged event handlers applied as well. it comes back with a valid IP, but won’t do anything.
could use some assistance with this as I’m on a dead line.
I was able to get it working now… I manually (in code) set the MAC Address for the ENC28 module (whereas before I used FEZ Config) and I noticed that my webservice host changed without my knowledge. I corrected both and it is working now.
