Have anyone manage to get PWM running faster then 9MHZ??
I need to get it to 10MHZ.
I use _pwm.SetPulse(100, 50);
Does anyone have tried set the PWM pulse with register access?
You might check this code I wrote for FEZ Cobra:
http://code.tinyclr.com/project/348/pwm-helper-class-with-clean-transitions/
There you see how the prescaler is calculated:
public void SetPulse(uint period_nanosecond, uint highTime_nanosecond)
// Adjust for 72 MHz / 4 clock
period_nanosecond *= 9;
period_nanosecond /= 500;
highTime_nanosecond *= 9;
highTime_nanosecond /= 500;
lock (syncLock)
if (pin == null)
throw new ObjectDisposedException();
mr0.Write(period_nanosecond); // Set the clock
mr.Write(highTime_nanosecond); // Set duty
ler.SetBits(1U | (1U << pin.Channel)); // Set latch enable bits for clock and duty
As you can see, the peripheral clock for PWM is derived from 72MHz/4 = 18MHz.So 18MHz will be the fastest clock you can get on PWM. Divided by two, that gives you the 9MHz clock you’re seeing. You cannot divide the peripheral clock by 1.8
I don’t know if you can change the peripheral clock to 36 MHz or 72 MHz, that way, you could get closer to 10Mhz (in all cases, you’ll never get a perfect 10MHz!). You’ll have to check the datasheet for that.
Aha, that explains the 9Mhz,
Thanks a lot for the info!
