I’ve been working on several FEZ Panda II projects but today I find myself in the position of not being able to debug anymore. Apparently my code is no longer being downloaded into the device. It will run what’s there but not download new code I think.
When I Select “Start Debugging” I always get the dialog that says “There were deployment issues. Continue?” If I say yes things continue as I’m used to but the debug output is always the same even though I have removed some of the code so I seem to be running old code every time and can’t change it.
I build and rebuild with no errors. What has changed and how do I correct it?
