After successfully working through examples on “The Internet of Things,” I’m attempting to connect a Panda II w/ Wiznet running as a client to a server program running on a PC but getting a timeout exception when calling socket.Connect(). The server on the PC uses System.Net.Sockets and the client on the Panda uses GHIElectronics.NETMF.Net.Sockets. Is there a problem using these two different sockets? The server instantiates a (.NET) TcpListener and calls listener.AcceptTcpClient() while the client instantiates a (GHI) Socket and calls socket.Connect(serverEndPoint). The timeout exception results. Both the server and client code were successfully tested on the same PC, both using System.Net.Sockets and then I attempted to port the client to the Panda and MF. Any ideas of why the client fails to connect? Relevant code follows and exeption report.
Client code:
using GHIElectronics.NETMF.Net.Sockets;
using GHIElectronics.NETMF.Net.NetworkInformation;
namespace MFTestConnection
const int cServerIP = 64;
const int cPort = 2000;
const byte cMicroControllerIP = 222;
static Socket socket;
byte[] ip = { 192, 168, 1, cMicroControllerIP };
byte[] subnet = { 255, 255, 255, 0 };
byte[] gateway = { 192, 168, 1, 254 };
byte[] mac = { 0x00, 0x88, 0x98, 0x90, 0xD4, 0xE0 };
try
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di7, true);
NetworkInterface.EnableStaticIP(ip, subnet, gateway, mac);
NetworkInterface.EnableStaticDns(new byte[] { 192, 168, 1, 254 });
catch (Exception e)
Debug.Print(e.Message);
bool connectedToDataServer = false;
IPEndPoint serverEndPoint = new IPEndPoint(new IPAddress(new byte[] { 192, 168, 1, cServerIP }), cPort);
Debug.Print("Connecting to server...");
do
socket = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
try
socket.Connect(serverEndPoint);
catch (Exception e)
socket.Close();
Debug.Print("waiting 5 seconds...");
Thread.Sleep(5000);
} while (!connectedToDataServer);
Server code:
using System.Collections.Generic;
using System.Text;
using System.IO;
using System.Net;
using System.Net.Sockets;
namespace PBRDataServer
class Program
const int cDataServerIP = 64;
const string cPBRDataFile = "PBRData.dat";
const int cDataPort = 2000; // must match port in DataStore class of MFPBR app
const int cBufSize = 256;
const int cReadWait = 1000;
const string cHandshake = "DataHandshake"; // must match handshake string in DataStore class of MFPBR app
const int cReconnectWait = 5000;
IPAddress serverIP = new IPAddress(new byte[] { 192, 168, 1, cDataServerIP });
StreamWriter txtDataOut = new StreamWriter(@ cPBRDataFile);
TcpListener listener = new TcpListener(serverIP, cDataPort);
TcpClient client;
byte[] buf = new byte[cBufSize];
int bytesRead = 0;
bool dataAvailable = false;
listener.Start();
Console.WriteLine("Data server started, listening to port {0}", cDataPort);
bool connectedToDataStore = false;
do {
client = listener.AcceptTcpClient(); // wait here until client connects
Console.WriteLine("Connected to client {0}", client.Client.RemoteEndPoint);
Client Output:
Connecting to server…
#### Exception System.Exception - 0x00000000 (1) ####
#### Message: Timeout occurs during connection establishment
#### GHIElectronics.NETMF.Net.SocketNative::connect [IP: 0135] ####
#### GHIElectronics.NETMF.Net.Sockets.Socket::Connect [IP: 002c] ####
#### MFTestConnection.Program::Main [IP: 00a7] ####
A first chance exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.W5100.dll
waiting 5 seconds…
The program ‘[2] Micro Framework application: Managed’ has exited with code 0 (0x0).
