Is there a new procedure for upgrading the firmware on a Raptor? I connected the two pins on socket 3 and pressed the reset button, then ran update.bat, which exited with an error message:
-I- Waiting ...
-I- TCL platform : Windows NT
-I- SAM-BA 2.12 on : windows
current connection is \USBserial\COM8, \\USBserial\\COM8 to be matched
-I- Retrieved arguments from command line :
-I- argv 0 : \USBserial\COM8
-I- argv 1 : at91sam9g15-ek
-I- argv 2 : Loader.tcl
-I- Connection : \USBserial\COM8 (target(comType) = 0)
-I- Board : at91sam9g15-ek
-I- Traces Level : 4
-I- target(handle) : 42133160
Read device Chip ID at 0xfffff240 --- get 0x819a05a1
-I- Found processor : at91sam9g15 (Chip ID : 0x819a05a1)
sourcing device file C:/Program Files (x86)/Atmel/sam-ba_2.12/sam-ba.exe/../tcl_lib/devices/at91sam9g15.tcl
sourcing board description file C:/Program Files (x86)/Atmel/sam-ba_2.12/sam-ba.exe/../tcl_lib/at91sam9g15-ek/at91sam9g15-ek.tcl
-I- Loading applet applet-lowlevelinit-sam9g15.bin at address 0x300000
-I- Memory Size : 0x0 bytes
-I- Buffer address : 0x4
-I- Buffer size: 0x0 bytes
-I- Applet initialization done
-I- Low level initialized
-I- External RAM Settings : extRamVdd=0, extRamType=1, extRamDataBusWidth=32, extDDRamModel=0
-I- Loading applet applet-extram-sam9g15.bin at address 0x300000
-I- Memory Size : 0x8000000 bytes
-I- Buffer address : 0x300B90
-I- External RAM initialized
-I- Command line mode : Execute script file : Loader.tcl
-I- DATAFLASH::Init 0 (trace level : 4)
-I- Loading applet applet-dataflash-sam9g15.bin at address 0x20000000
-E- Script File Loader.tcl returned error : Error Initializing DataFlash Applet (Can't detect known device) - Error Initializing DataFlash Applet (Can't detect known device)
while executing
"error "Error Initializing DataFlash Applet ($dummy_err)""
(procedure "DATAFLASH::Init" line 14)
invoked from within
"DATAFLASH::Init 0"
(file "Loader.tcl" line 11)
invoked from within
"source $scriptFile"
No expert on the subject but I have set the new firmware (latest two versions) without doing anything on the Raptor. (No jumpers used).
I did have one issue and it was solved by erasing the existing application and then doing the update.
As I remember all I had to do was start the new FEZ Configure. Device USB, G400_G400.
Clicked Check device for update to be sure things were talking and then went to the Firmware Updater.
Yup. Me too although I get a simpler message from update.bat:
Updating…
Access is denied.
Done.
Press any key to continue . . .
I had trouble finding the instructions and the only ones I could find are not correct (different directory location and different batch file location). However they worked for 4.3.3 but can’t get the batch file to work for 4.3.4
No luck. I re-installed all GHI SDK parts. FEZconfig cannot see the board. update.bat just freezes forever, or terminates with an error message. I tried a different USB port, giving me a different COMx port number, no luck. I re-booted the PC. Is there an alternate way to load the tinybooter? Using a terminal program?
