I’ve been trying for several days (on and off) to update my Hydra to the 4.2FW.
I’ve used the HydraFirmwareUpdater - it fails every time with:
Hydra found at Port#: COM3
Device will be updated automatically! DO NOT disconnect or turn off the device!
Updating Firmware. Please wait…
Error while connecting to the device. Try again
or visit GHI Electronics – Where Hardware Meets Software for information to update manually.
This is with a Hydra where I erased using the boot.bin on an SD card - properly comes up with serial port (indicated above).
The tinybooter portion gets loaded, a request to reboot dialog comes up, I do that, then click (the now enabled) Next, which is when I get the “Error while connecting to the device” message.
Further attempts to update returns “Connecting to device… Failed” until I re-erase with the SD card (or MISO trick).
I’ve attempted a manual update instead - in this case, I get through loading the TinyBooter and am usually only mildly confused by the plethora of “enter TinyBooter mode” instructions followed by “you don’t need to do that” part.
Once I get TinyBooter loaded and started (the device shows up as a USB device now), MFDeploy will NOT deploy the firmware - it reports a dialog with something like “Object cannot be null”, then reports no communication with the Hydra.
I’m slightly suspicious of my USB drivers (although this is on a machine (a VM) that has NEVER had 4.1 installed).
The drivers in the Windows/system32/drivers directory are 35Kb, while the drivers under the GHI folder are 28K - so I’m suspicious. However, when I manually installed the one from the GHI folder (GHI_NETMF_Interface.sys), the system REALLY didn’t like it… Although, I’m running Win7-64bit - so not sure if those are the current drivers anyway, although that’s what the properties reported it was…
Suggestions?
– Hugh
