Rebooting…
Create TS.
Loading start at 2019a448, end 201a3f94
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1112 bytes ( 139 elements)
FieldDef = 272 bytes ( 135 elements)
MethodDef = 1572 bytes ( 786 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 1551 bytes
Signatures = 2126 bytes
ByteCode = 11702 bytes
Attaching file.
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
AssemblyRef = 4 bytes ( 1 elements)
TypeRef = 80 bytes ( 20 elements)
MethodRef = 60 bytes ( 15 elements)
TypeDef = 336 bytes ( 42 elements)
FieldDef = 192 bytes ( 95 elements)
MethodDef = 224 bytes ( 111 elements)
Attributes = 48 bytes ( 6 elements)
TypeSpec = 0 bytes ( 0 elements)
Resources = 72 bytes ( 9 elements)
Resources Files = 8 bytes ( 1 elements)
Resources Data = 747 bytes
Strings = 648 bytes
Signatures = 595 bytes
ByteCode = 418 bytes
Attaching deployed file.
Assembly: Microsoft.SPOT.IO (4.1.2821.0) (740 RAM - 4620 ROM - 2522 METADATA)
AssemblyRef = 12 bytes ( 3 elements)
TypeRef = 76 bytes ( 19 elements)
MethodRef = 112 bytes ( 28 elements)
TypeDef = 120 bytes ( 15 elements)
FieldDef = 72 bytes ( 35 elements)
MethodDef = 140 bytes ( 70 elements)
Resources = 0 bytes ( 0 elements)
Resources Files = 0 bytes ( 0 elements)
Resources Data = 0 bytes
Strings = 676 bytes
Signatures = 350 bytes
ByteCode = 1295 bytes
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
AssemblyRef = 8 bytes ( 2 elements)
TypeRef = 124 bytes ( 31 elements)
FieldRef = 24 bytes ( 6 elements)
MethodRef = 120 bytes ( 30 elements)
TypeDef = 496 bytes ( 62 elements)
FieldDef = 176 bytes ( 88 elements)
MethodDef = 444 bytes ( 222 elements)
Strings = 1329 bytes
Signatures = 1067 bytes
ByteCode = 2611 bytes
Assembly: GHIElectronics.NETMF.Net (4.1.3.0) (404 RAM - 2300 ROM - 919 METADATA)
AssemblyRef = 20 bytes ( 5 elements)
TypeDef = 32 bytes ( 4 elements)
FieldDef = 8 bytes ( 4 elements)
MethodDef = 44 bytes ( 21 elements)
Strings = 881 bytes
Signatures = 115 bytes
ByteCode = 371 bytes
Assembly: System (4.1.2821.0) (872 RAM - 5992 ROM - 3206 METADATA)
MethodRef = 172 bytes ( 43 elements)
TypeDef = 144 bytes ( 18 elements)
FieldDef = 56 bytes ( 28 elements)
MethodDef = 184 bytes ( 92 elements)
Strings = 21 bytes
Signatures = 546 bytes
ByteCode = 2635 bytes
Assembly: GHIElectronics.NETMF.USBHost (4.1.3.0) (1528 RAM - 14664 ROM - 6396 METADATA)
TypeRef = 88 bytes ( 22 elements)
FieldRef = 12 bytes ( 3 elements)
MethodRef = 88 bytes ( 22 elements)
FieldDef = 260 bytes ( 130 elements)
MethodDef = 396 bytes ( 198 elements)
TypeSpec = 4 bytes ( 1 elements)
Strings = 3625 bytes
Signatures = 764 bytes
ByteCode = 4514 bytes
Assembly: Microsoft.SPOT.Net (4.1.2821.0) (704 RAM - 5060 ROM - 2452 METADATA)
TypeRef = 96 bytes ( 24 elements)
MethodRef = 76 bytes ( 19 elements)
FieldDef = 60 bytes ( 29 elements)
MethodDef = 136 bytes ( 68 elements)
Strings = 1280 bytes
Signatures = 388 bytes
ByteCode = 1204 bytes
Assembly: ManagedDrivers.Modems.AirlinkGL_6110.Demo2 (1.0.0.0) (592 RAM - 5164 ROM - 1469 METADATA)
AssemblyRef = 36 bytes ( 9 elements)
TypeRef = 120 bytes ( 30 elements)
FieldRef = 28 bytes ( 7 elements)
MethodRef = 148 bytes ( 37 elements)
TypeDef = 48 bytes ( 6 elements)
FieldDef = 28 bytes ( 13 elements)
MethodDef = 32 bytes ( 16 elements)
Strings = 1960 bytes
Signatures = 265 bytes
ByteCode = 1606 bytes
Assembly: System.IO (4.1.2821.0) (1548 RAM - 13292 ROM - 5862 METADATA)
TypeRef = 168 bytes ( 42 elements)
FieldRef = 36 bytes ( 9 elements)
MethodRef = 392 bytes ( 98 elements)
FieldDef = 76 bytes ( 37 elements)
MethodDef = 392 bytes ( 195 elements)
TypeSpec = 8 bytes ( 2 elements)
Strings = 356 bytes
Signatures = 790 bytes
ByteCode = 6946 bytes
Assembly: ManagedDrivers.Modems.AirlinkGL_61x0 (1.0.0.0) (1948 RAM - 30860 ROM - 7711 METADATA)
AssemblyRef = 24 bytes ( 6 elements)
TypeRef = 192 bytes ( 48 elements)
FieldRef = 8 bytes ( 2 elements)
MethodRef = 468 bytes ( 117 elements)
TypeDef = 296 bytes ( 37 elements)
FieldDef = 156 bytes ( 77 elements)
MethodDef = 444 bytes ( 221 elements)
Strings = 5351 bytes
Signatures = 1263 bytes
ByteCode = 17672 bytes
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.1.2821.0) (508 RAM - 3440 ROM - 1527 METADATA)
MethodRef = 80 bytes ( 20 elements)
TypeDef = 16 bytes ( 2 elements)
FieldDef = 32 bytes ( 16 elements)
MethodDef = 92 bytes ( 46 elements)
Strings = 667 bytes
Signatures = 239 bytes
ByteCode = 1118 bytes
Assembly: GHIElectronics.NETMF.System (4.1.3.0) (440 RAM - 2220 ROM - 1281 METADATA)
TypeRef = 36 bytes ( 9 elements)
MethodRef = 48 bytes ( 12 elements)
TypeDef = 72 bytes ( 9 elements)
MethodDef = 72 bytes ( 36 elements)
Strings = 496 bytes
Signatures = 181 bytes
ByteCode = 314 bytes
Resolving.
Total: (13960 RAM - 138804 ROM - 64329 METADATA)
AssemblyRef = 168 bytes ( 42 elements)
TypeRef = 1232 bytes ( 308 elements)
FieldRef = 108 bytes ( 27 elements)
MethodRef = 1824 bytes ( 456 elements)
TypeDef = 3272 bytes ( 409 elements)
FieldDef = 1416 bytes ( 700 elements)
MethodDef = 4172 bytes ( 2082 elements)
DebuggingInfo = 2100 bytes
TypeSpec = 32 bytes ( 8 elements)
Resources Files = 72 bytes ( 3 elements)
Resources = 304 bytes ( 38 elements)
Resources Data = 1184 bytes
Strings = 18841 bytes
Signatures = 8689 bytes
ByteCode = 52406 bytes
GC: 1msec 20268 bytes used, 59745792 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 59745792 bytes
Type 17 (ASSEMBLY ): 16128 bytes
Type 1E (BINARY_BLOB_HEAD ): 4044 bytes
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.System.dll’
Invalid address 0 and range 40 Ram Start 20000000, Ram end 24000000
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.Net.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.USBHost.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘ManagedDrivers.Modems.AirlinkGL_61x0’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘ManagedDrivers.Modems.AirlinkGL_6110.Demo2’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.IO.dll’, Symbols loaded.
