Installed all the software, no problem. When I try to create a new project and select C# and .Net Gadgeteer App (NETMF 4.2) . I get an error message that it cannot open a file that ends with .csprog and that that file type is not supported (see attached image of error message). Can’t go any further.
The project type Gadgeteer show up under C#. When I select the Gadgeteer type I get a choice of NETMF 4.1 or NETMF4.2. Since I am using the Cerburus I choose 4.2.
I seems like it might be a permission problem. I am using Windows 7.
I have installed both the sdk and GHI NETMF v4.2 and .NET Gadgeteer Package (10-24-2012), but I am still getting the same error
"Device not found or cannot be opened - USB:Gadgeteer========== Deploy: 0 succeeded, 1 failed, 0 skipped ==========
Few inputs:
while creating the project, I choose NETMF4.2
I had the problem device not being recognized by win7 like few others, and followed the blog’s, resolved it by updating the drivers manually by pointing to suggested location.
I get the click sound when I connect the device to the system.
(but in the meantime, your image shows it doesn’t have a netmf firmware on it, it’s in bootloader mode. Looks like you either need to get out of bootloader mode or put netmf firmware on it)
