How is the debugging of RLP typically performed? What techniques does one use to detect and fix problems in the C code?
I used the following to get started:
https://www.ghielectronics.com/community/codeshare/entry/268
I suppose you could also use events to dump some debug data back to the managed side:
Someone should write a visual studio extension to step through RLP code.
I mean, how hard can it be? It’s all just bits…just moving bits around.
