Using VS 2010 I used to be able to deploy to my Domino device, but now I get a ‘Check Hardware’ message.
I’ve uninstalled everything, then installed :-
MS Microframework 4.1 SDK
GHI SDK 4.1 (Version 1.0.11)
GHI NETMF USB Drivers 64-Bit Auto Installer
I’ve used MSDeploy and erased the device.
Then I’ve used TeraTerm and Tranmitted C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\USBizi\Firmware\USBizi_CLR.GHI sucessfully, then disconnected.
I still get, when pressing ‘V’ in firmware update mode, 1.07 coming from the board?
It this the correct version??
Using MSDeploy, connecting and list Device Capabilies I get :-
Pinging… TinyCLR
HalSystemInfo.halVersion:
HalSystemInfo.halVendorInfo:
HalSystemInfo.oemCode: 0
HalSystemInfo.modelCode: 0
HalSystemInfo.skuCode: 0
HalSystemInfo.moduleSerialNumber:
HalSystemInfo.systemSerialNumber:
ClrInfo.clrVersion: 4.1.2821.0
ClrInfo.clrVendorInfo: Microsoft Copyright © Microsoft Corporation. All rig
ClrInfo.targetFrameworkVersion: 4.1.2821.0
SolutionReleaseInfo.solutionVersion: 4.1.3.0
SolutionReleaseInfo.solutionVendorInfo: GHI Electronics, LLC
SoftwareVersion.BuildDate: Oct 15 2010
SoftwareVersion.CompilerVersion: 310739
FloatingPoint: True
SourceLevelDebugging: True
ThreadCreateEx: True
LCD.Width: 0
LCD.Height: 0
LCD.BitsPerPixel: 0
AppDomains: True
ExceptionFilters: True
IncrementalDeployment: True
SoftReboot: True
Profiling: False
ProfilingAllocations: False
ProfilingCalls: False
IsUnknown: False
And finaly, VS assemblies have been removed and re-added, these are :-
All GHI assemblies are Runtime Version v4.0.30319 and version 4.1.3.0
All Microsoft assemblies are Runtime Version v4.0.30319 and version 4.1.2821.0.
Is version 4.1.2821.0 correct, should it not be 1.4.3.0, if so how do this?
Jason.
