When I try and create a new Fez Panda II project in VS Pro I get the following error
The project type is not supported by this installation.
I use VS2010 pro on my home machine and it works fine, but when I try and open the same project on my work machine I also get that same error.
I have re-installed the .net SDK and the GHI sdk but it will not solve the issue.
I do have VS2010 Express on my machine as well and I can open these projects in that. Is it not possible to have both Express and Pro on the same computer? I am afraid to remove the Express version as that is the only way I can work on my Fez projects right now.
On my work machine this is the sequence of installations
Installed 2010 express and the GHI SDKs was developing USBizi projects for a while
Purchased 2010 pro and was doing some windows development
Tried to load my Fez projects created with express and got the error above.
Re-insalled the latest GHI sdk, did not fix issue
Re-Installed MS SDK, did not fix,
Re-Installed GHI SDK again, did not fix problem
If I remove the ProjectTypeGuids from the .csproj file then the project will load but I am missing the .net Micro Framework tab on the project properties.
Anyone have suggestions on how to fix this?
Shawn
