Does the 9 Pin (male) D-Sub on the CAN DW module use this standard (open) pin out?
[url]http://www.interfacebus.com/Can_Bus_Connector_Pinout.html[/url]
I could not find the info on tinclr or the GHI web page and I hate to assume.
The link I provided shows several optional connections, are those optional connection implemented on this module? If so, is there a requirement for voltage on pin 9?
Will this module work correctly if one only hooks up Pin 2 to Can_Low, Pin 7 to Can_High and Pin 3 to vehicle ground?
Thanks for the help.
