I ran a piece of code on my Cerb to set the time and now, after several attempts including wiping the application off the device with FezConfig; I cannot communicate with the device at all.
Should I be soldering in jumpers into the LDR header and trying for a tinybooter update?
@ Brett - I had to wipe it, run STM32 dfuse and reapply the tinybooter then put back the firmware then the application. Good thing I soldered on a jumper first. Did you mean 10ms or 10 seconds, seconds?
