I wish to use SPI to connect a Panda II to a host processor. Seems reasonable that the Host is the master. Can the Panda II act as a slave? The reason that I am asking is because I cannot find a SPI Device select input on the board.
Looking at the reply from Gus here: http://www.tinyclr.com/forum/18/1850/#/1/msg19551 , guess the same goes for the Panda.
You can but with RLP drivers
Hi Guys
Sorry to be dense but replys are terse.
I think that Gus’s answer is NO using the normal SDI interface!
What are RLP Drivers? Some docs suggest they are harware but that seems unlikely.
Humour me - I’m new.
Basically, no you can’t run as a PSI slave as NETMF only include master SPI drivers.
With that being said, you can write your own drivers, in C not C# to use SPI slave. This will not be easy if you are not familiar with C programming, with SPI itself and with microcontrollers.
In my opinion, it is too much work for little benefit. Why do you need SPI slave?!
