posting it on forum
Hello,
There is no attached photo. Also, please use the forum for technical support.
Regards,
Gus Issa
GHI Electronics, LLC
51410 Milano Dr STE 114
Macomb Township, MI 48042
USA
PH: +1 586 693 2696
FAX: +1 586 693 3449
Sent: Tuesday, April 03, 2012 11:20 AM
To: GHI Support Team ; Amit Puri
Subject: RE: Confirmation of your order 4916048 from Mouser Electronics, Inc.
Hi, Gus Issa
I have written app based on http://tinyclr.com/forum/21/6073/ and executed. See attach photo and code attached for your reference.
Still I am not able to see anything on the photo. Please help
Debug from VS2010
Rebooting…
Create TS.
Loading start at a0200000, end a0209b4c
Attaching file.
Assembly: mscorlib (4.1.2821.0) (3880 RAM - 33236 ROM - 19134 METADATA)
AssemblyRef = 0 bytes ( 0 elements)
TypeRef = 0 bytes ( 0 elements)
FieldRef = 0 bytes ( 0 elements)
MethodRef = 0 bytes ( 0 elements)
TypeDef = 1112 bytes ( 139 elements)
FieldDef = 272 bytes ( 135 elements)
MethodDef = 1572 bytes ( 786 elements)
Attributes = 0 bytes ( 0 elements)
TypeSpec = 16 bytes ( 4 elements)
Resources = 232 bytes ( 29 elements)
Resources Files = 16 bytes ( 2 elements)
Resources Data = 437 bytes
Strings = 1551 bytes
Signatures = 2126 bytes
ByteCode = 11702 bytes
Attaching file.
Assembly: Microsoft.SPOT.Native (4.1.2821.0) (1144 RAM - 6516 ROM - 4479 METADATA)
AssemblyRef = 4 bytes ( 1 elements)
TypeRef = 80 bytes ( 20 elements)
MethodRef = 60 bytes ( 15 elements)
TypeDef = 336 bytes ( 42 elements)
FieldDef = 192 bytes ( 95 elements)
MethodDef = 224 bytes ( 111 elements)
Attributes = 48 bytes ( 6 elements)
TypeSpec = 0 bytes ( 0 elements)
Resources = 72 bytes ( 9 elements)
Resources Files = 8 bytes ( 1 elements)
Resources Data = 747 bytes
Strings = 648 bytes
Signatures = 595 bytes
ByteCode = 418 bytes
Attaching deployed file.
Assembly: Gadgeteer.WebServer (2.41.0.0) (1012 RAM - 9536 ROM - 3505 METADATA)
AssemblyRef = 20 bytes ( 5 elements)
TypeRef = 148 bytes ( 37 elements)
FieldRef = 4 bytes ( 1 elements)
MethodRef = 264 bytes ( 66 elements)
TypeDef = 80 bytes ( 10 elements)
FieldDef = 96 bytes ( 48 elements)
MethodDef = 176 bytes ( 88 elements)
TypeSpec = 4 bytes ( 1 elements)
Resources = 0 bytes ( 0 elements)
Resources Files = 0 bytes ( 0 elements)
Resources Data = 0 bytes
Strings = 2812 bytes
Signatures = 577 bytes
ByteCode = 3089 bytes
Assembly: Microsoft.SPOT.Net.Security (4.1.2821.0) (264 RAM - 1220 ROM - 606 METADATA)
TypeRef = 12 bytes ( 3 elements)
MethodRef = 4 bytes ( 1 elements)
TypeDef = 32 bytes ( 4 elements)
FieldDef = 16 bytes ( 8 elements)
MethodDef = 40 bytes ( 19 elements)
Strings = 404 bytes
Signatures = 98 bytes
ByteCode = 81 bytes
Assembly: Microsoft.SPOT.Touch (4.1.2821.0) (408 RAM - 2332 ROM - 1176 METADATA)
AssemblyRef = 16 bytes ( 4 elements)
TypeRef = 44 bytes ( 11 elements)
MethodRef = 16 bytes ( 4 elements)
TypeDef = 72 bytes ( 9 elements)
FieldDef = 24 bytes ( 12 elements)
MethodDef = 64 bytes ( 32 elements)
Strings = 747 bytes
Signatures = 176 bytes
ByteCode = 283 bytes
Assembly: GTM.GHIElectronics.Camera (4.1.1.2) (748 RAM - 6932 ROM - 2249 METADATA)
AssemblyRef = 24 bytes ( 6 elements)
TypeRef = 132 bytes ( 33 elements)
FieldRef = 12 bytes ( 3 elements)
MethodRef = 168 bytes ( 42 elements)
TypeDef = 64 bytes ( 8 elements)
FieldDef = 60 bytes ( 29 elements)
MethodDef = 100 bytes ( 50 elements)
Strings = 2872 bytes
Signatures = 329 bytes
ByteCode = 1684 bytes
Assembly: Microsoft.SPOT.Net (4.1.2821.0) (704 RAM - 5060 ROM - 2452 METADATA)
AssemblyRef = 12 bytes ( 3 elements)
TypeRef = 96 bytes ( 24 elements)
MethodRef = 76 bytes ( 19 elements)
TypeDef = 120 bytes ( 15 elements)
MethodDef = 136 bytes ( 68 elements)
Strings = 1280 bytes
Signatures = 388 bytes
ByteCode = 1204 bytes
Assembly: System.Net.Security (4.1.2821.0) (664 RAM - 4544 ROM - 1943 METADATA)
TypeRef = 112 bytes ( 28 elements)
FieldRef = 16 bytes ( 4 elements)
MethodRef = 176 bytes ( 44 elements)
TypeDef = 56 bytes ( 7 elements)
MethodDef = 84 bytes ( 42 elements)
Strings = 935 bytes
Signatures = 347 bytes
ByteCode = 1538 bytes
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.1.2.0) (828 RAM - 6320 ROM - 2151 METADATA)
TypeRef = 164 bytes ( 41 elements)
FieldRef = 140 bytes ( 35 elements)
MethodRef = 180 bytes ( 45 elements)
FieldDef = 36 bytes ( 18 elements)
MethodDef = 56 bytes ( 27 elements)
Strings = 1950 bytes
Signatures = 343 bytes
ByteCode = 2091 bytes
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.1.2821.0) (508 RAM - 3440 ROM - 1527 METADATA)
AssemblyRef = 8 bytes ( 2 elements)
MethodRef = 80 bytes ( 20 elements)
TypeDef = 16 bytes ( 2 elements)
FieldDef = 32 bytes ( 16 elements)
MethodDef = 92 bytes ( 46 elements)
Strings = 667 bytes
Signatures = 239 bytes
ByteCode = 1118 bytes
Assembly: Gadgeteer.WebClient (2.41.0.0) (880 RAM - 6928 ROM - 2847 METADATA)
MethodRef = 224 bytes ( 56 elements)
TypeDef = 88 bytes ( 11 elements)
FieldDef = 48 bytes ( 24 elements)
Strings = 2020 bytes
Signatures = 475 bytes
ByteCode = 1933 bytes
Assembly: GTM.GHIElectronics.Display_T35 (4.1.2.0) (468 RAM - 2780 ROM - 1040 METADATA)
AssemblyRef = 28 bytes ( 7 elements)
TypeRef = 88 bytes ( 22 elements)
FieldRef = 64 bytes ( 16 elements)
FieldDef = 8 bytes ( 4 elements)
MethodDef = 32 bytes ( 16 elements)
Strings = 1069 bytes
Signatures = 156 bytes
ByteCode = 542 bytes
Assembly: GHIElectronics.NETMF.IO (4.1.8.0) (212 RAM - 664 ROM - 289 METADATA)
FieldRef = 8 bytes ( 2 elements)
TypeDef = 8 bytes ( 1 elements)
FieldDef = 4 bytes ( 2 elements)
MethodDef = 20 bytes ( 9 elements)
Strings = 212 bytes
Signatures = 33 bytes
ByteCode = 36 bytes
Assembly: System (4.1.2821.0) (872 RAM - 5992 ROM - 3206 METADATA)
TypeRef = 76 bytes ( 19 elements)
MethodRef = 172 bytes ( 43 elements)
TypeDef = 144 bytes ( 18 elements)
FieldDef = 56 bytes ( 28 elements)
MethodDef = 184 bytes ( 92 elements)
Strings = 21 bytes
Signatures = 546 bytes
ByteCode = 2635 bytes
Assembly: GTM.GHIElectronics.Button (4.1.1.0) (368 RAM - 2008 ROM - 863 METADATA)
TypeRef = 68 bytes ( 17 elements)
MethodRef = 52 bytes ( 13 elements)
MethodDef = 36 bytes ( 18 elements)
Strings = 542 bytes
Signatures = 151 bytes
ByteCode = 474 bytes
Assembly: GHIElectronics.NETMF.Hardware (4.1.8.0) (1268 RAM - 8732 ROM - 5109 METADATA)
TypeRef = 100 bytes ( 25 elements)
MethodRef = 104 bytes ( 26 elements)
TypeDef = 320 bytes ( 40 elements)
FieldDef = 128 bytes ( 64 elements)
MethodDef = 312 bytes ( 156 elements)
Strings = 2190 bytes
Signatures = 697 bytes
ByteCode = 1301 bytes
Assembly: GHIElectronics.NETMF.USBHost (4.1.8.0) (1668 RAM - 15824 ROM - 7067 METADATA)
TypeRef = 92 bytes ( 23 elements)
MethodRef = 88 bytes ( 22 elements)
TypeDef = 376 bytes ( 47 elements)
FieldDef = 280 bytes ( 139 elements)
MethodDef = 444 bytes ( 221 elements)
Strings = 3948 bytes
Signatures = 855 bytes
ByteCode = 4683 bytes
Assembly: System.Http (4.1.2821.0) (2976 RAM - 38160 ROM - 12831 METADATA)
TypeRef = 256 bytes ( 64 elements)
MethodRef = 576 bytes ( 144 elements)
TypeDef = 416 bytes ( 52 elements)
FieldDef = 344 bytes ( 172 elements)
MethodDef = 816 bytes ( 408 elements)
Strings = 9362 bytes
Signatures = 1947 bytes
ByteCode = 15837 bytes
Assembly: Microsoft.SPOT.TinyCore (4.1.2821.0) (5048 RAM - 61120 ROM - 23305 METADATA)
TypeRef = 220 bytes ( 55 elements)
FieldRef = 52 bytes ( 13 elements)
MethodRef = 456 bytes ( 114 elements)
TypeDef = 1096 bytes ( 137 elements)
FieldDef = 720 bytes ( 360 elements)
MethodDef = 1568 bytes ( 784 elements)
Strings = 12896 bytes
Signatures = 3085 bytes
ByteCode = 24789 bytes
Assembly: System.IO (4.1.2821.0) (1548 RAM - 13292 ROM - 5862 METADATA)
TypeRef = 168 bytes ( 42 elements)
FieldRef = 36 bytes ( 9 elements)
MethodRef = 392 bytes ( 98 elements)
FieldDef = 76 bytes ( 37 elements)
MethodDef = 392 bytes ( 195 elements)
TypeSpec = 8 bytes ( 2 elements)
Strings = 356 bytes
Signatures = 790 bytes
ByteCode = 6946 bytes
Assembly: Microsoft.SPOT.Hardware (4.1.2821.0) (1752 RAM - 11440 ROM - 7371 METADATA)
TypeRef = 124 bytes ( 31 elements)
FieldRef = 24 bytes ( 6 elements)
MethodRef = 120 bytes ( 30 elements)
TypeDef = 496 bytes ( 62 elements)
FieldDef = 176 bytes ( 88 elements)
MethodDef = 444 bytes ( 222 elements)
Strings = 1329 bytes
Signatures = 1067 bytes
ByteCode = 2611 bytes
Assembly: GHIElectronics.NETMF.System (4.1.8.0) (488 RAM - 2496 ROM - 1465 METADATA)
TypeRef = 48 bytes ( 12 elements)
MethodRef = 56 bytes ( 14 elements)
FieldDef = 28 bytes ( 14 elements)
MethodDef = 84 bytes ( 41 elements)
Strings = 549 bytes
Signatures = 213 bytes
ByteCode = 349 bytes
Assembly: FirstGadgeteerApp (1.0.0.0) (476 RAM - 5424 ROM - 1018 METADATA)
AssemblyRef = 36 bytes ( 9 elements)
MethodRef = 124 bytes ( 31 elements)
TypeDef = 24 bytes ( 3 elements)
FieldDef = 12 bytes ( 6 elements)
MethodDef = 20 bytes ( 10 elements)
Resources = 24 bytes ( 3 elements)
Resources Data = 2820 bytes
Strings = 1058 bytes
Signatures = 158 bytes
ByteCode = 350 bytes
Assembly: Microsoft.SPOT.IO (4.1.2821.0) (740 RAM - 4620 ROM - 2522 METADATA)
MethodRef = 112 bytes ( 28 elements)
FieldDef = 72 bytes ( 35 elements)
MethodDef = 140 bytes ( 70 elements)
Strings = 676 bytes
Signatures = 350 bytes
ByteCode = 1295 bytes
Assembly: GTM.GHIElectronics.UsbClientDP (4.1.1.0) (196 RAM - 492 ROM - 166 METADATA)
TypeRef = 20 bytes ( 5 elements)
FieldDef = 0 bytes ( 0 elements)
MethodDef = 4 bytes ( 1 elements)
Strings = 144 bytes
Signatures = 30 bytes
ByteCode = 55 bytes
Assembly: Microsoft.SPOT.Graphics (4.1.2821.0) (388 RAM - 2268 ROM - 1357 METADATA)
TypeRef = 24 bytes ( 6 elements)
MethodRef = 20 bytes ( 5 elements)
TypeDef = 40 bytes ( 5 elements)
MethodDef = 96 bytes ( 48 elements)
Strings = 537 bytes
Signatures = 293 bytes
ByteCode = 242 bytes
Assembly: Gadgeteer (2.41.0.0) (3832 RAM - 45256 ROM - 16148 METADATA)
TypeRef = 404 bytes ( 101 elements)
FieldRef = 84 bytes ( 21 elements)
MethodRef = 740 bytes ( 185 elements)
TypeDef = 632 bytes ( 79 elements)
FieldDef = 460 bytes ( 229 elements)
MethodDef = 892 bytes ( 446 elements)
Strings = 15676 bytes
Signatures = 2720 bytes
ByteCode = 13306 bytes
Resolving.
Total: (29232 RAM - 306632 ROM - 131688 METADATA)
AssemblyRef = 392 bytes ( 98 elements)
TypeRef = 2920 bytes ( 730 elements)
FieldRef = 476 bytes ( 119 elements)
MethodRef = 4360 bytes ( 1090 elements)
TypeDef = 5992 bytes ( 749 elements)
FieldDef = 3256 bytes ( 1620 elements)
MethodDef = 8164 bytes ( 4074 elements)
DebuggingInfo = 4108 bytes
TypeSpec = 48 bytes ( 12 elements)
Resources Files = 96 bytes ( 4 elements)
Resources = 328 bytes ( 41 elements)
Resources Data = 4004 bytes
Strings = 66451 bytes
Signatures = 18784 bytes
ByteCode = 100592 bytes
GC: 1msec 37740 bytes used, 13003308 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 13003308 bytes
Type 17 (ASSEMBLY ): 33456 bytes
Type 18 (WEAKCLASS ): 144 bytes
Type 1E (BINARY_BLOB_HEAD ): 4044 bytes
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.1\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.1\le\Gadgeteer.WebServer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.System.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.USBHost.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Camera\NETMF 4.1\le\GTM.GHIElectronics.Camera.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.IO.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.1 SDK\Assemblies\le\GHIElectronics.NETMF.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZSpider\NETMF 4.1\le\GHIElectronics.Gadgeteer.FEZSpider.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\System.Http.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.1\le\Gadgeteer.WebClient.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Display_T35\NETMF 4.1\le\GTM.GHIElectronics.Display_T35.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Button\NETMF 4.1\le\GTM.GHIElectronics.Button.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\UsbClientDP\NETMF 4.1\le\GTM.GHIElectronics.UsbClientDP.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘D:\gadgeteer\FirstGadgeteerApp\FirstGadgeteerApp\bin\Debug\le\FirstGadgeteerApp.exe’, Symbols loaded.
Using mainboard GHIElectronics-FEZSpider version 1.0
Program Started
Camera Cnnected!
Connected Camera Information…
Camera Resolution: Height: 240 Width: 320
Camera Ready: True
GC: 21msec 915096 bytes used, 12125952 bytes available
Type 0F (STRING ): 1356 bytes
Type 11 (CLASS ): 15768 bytes
Type 12 (VALUETYPE ): 1524 bytes
Type 13 (SZARRAY ): 236004 bytes
Type 15 (FREEBLOCK ): 12125952 bytes
Type 16 (CACHEDBLOCK ): 72 bytes
Type 18 (WEAKCLASS ): 240 bytes
Type 19 (REFLECTION ): 168 bytes
Type 1B (DELEGATE_HEAD ): 1476 bytes
Type 1C (DELEGATELIST_HEAD ): 108 bytes
Type 1D (OBJECT_TO_EVENT ): 264 bytes
Type 1E (BINARY_BLOB_HEAD ): 617436 bytes
Type 1F (THREAD ): 1152 bytes
Type 20 (SUBTHREAD ): 144 bytes
Type 21 (STACK_FRAME ): 1656 bytes
Type 22 (TIMER_HEAD ): 72 bytes
Type 23 (LOCK_HEAD ): 60 bytes
Type 24 (LOCK_OWNER_HEAD ): 24 bytes
Type 26 (WAIT_FOR_OBJECT_HEAD): 48 bytes
Type 27 (FINALIZER_HEAD ): 168 bytes
Type 31 (IO_PORT ): 216 bytes
Type 36 (APPDOMAIN_ASSEMBLY ): 3612 bytes
Amit Puri
From: GHI Support Team [mailto:ghielec@ ghielectronics.com]
Sent: 03 April 2012 17:57
To: Amit Puri; Amit Puri
Subject: Re: Confirmation of your order 4916048 from Mouser Electronics, Inc.
Hello,
I already replied yesterday but your email rejected my reply! I am adding your Microsoft email this time.
Always use forum for questions http://tinyclr.com/forum/
Please see this http://tinyclr.com/forum/21/6073/
Regards,
Gus Issa
USA
PH: +1 586 693 2696
Sent: Monday, April 02, 2012 7:28 PM
To: ghielec@ ghielectronics.com
Subject: Fw: Confirmation of your order 4916048 from Mouser Electronics, Inc.
I have received the Spider starter kit, yesterday evening. thanks for speedy delivery.
I have an issue with Camera module in the Spider starter kit. It is showing some photo but it is not at all clear,
can you please help me in this??
Amit Puri
----- Forwarded Message -----
To: “‘amitsoft@ yahoo.com’” <amitsoft@ yahoo.com>
Sent: Monday, April 2, 2012 10:00 AM
Subject: FW: Confirmation of your order 4916048 from Mouser Electronics, Inc.
Dear Sir,
Please note , we being the distributors – we request you to get in touch with the supplier technical support.
som@ ghielectronics.com.
Manjula Girish
Email : manjula.girish@ mouser.com // Ph : 91 80 41148091/92// Fax : 91 80 41148093
Mouser India-Sales , 106 preseitge Center point , Edward Road, Bangalore : 560052
Sent: Sunday, April 01, 2012 11:27 PM
To: India@ mouser.com
Further to the below please ask customer to contact supplier support at som@ ghielectronics.com.
Jithesh
From: Manjula.Girish@ mouser.com On Behalf Of India@ mouser.com
Sent: Monday, April 02, 2012 9:34 AM
To: Jithesh Kumar
Please review and incase of the additional information requested – let me know.
Sent: Friday, March 30, 2012 10:12 PM
I have an issue with Camera module in the Spider starter kit. It is showing some photo but it is not all clear,
Amit Puri
To: Amit Puri <amitsoft@ yahoo.com>
Sent: Tuesday, March 27, 2012 9:55 PM
Subject: Confirmation of your order 4916048 from Mouser Electronics, Inc.
Buyer Name : AMIT PURI
Purchase Order No. : 4916048
Sales Order No. : 222381518
Web Order No. : 4916048
Customer No. : 5226357
Amit Puri,
Thank you for placing your order with Mouser Electronics, Inc. For your reference, a summary of your order is included below.
As soon as your order is shipped, you will receive an e-mail.
If you have any questions about your order, please reply to this e-mail or call our customer service team in Bangalore at +91 80-4114-8091 .
Thank you and we appreciate your business.
Internet Customer Service
