My Camera seem has some trouble.
I simply test this, but
output shows
Using mainboard GHI Electronics FEZSpider version 1.0
Camera ERROR : Unable to take picture. Camera is not ready. Is the Camera connected?
Program Started
I am sure the Camera is connected and I have changed the wire. The result is the same.
public partial class Program
camera.TakePicture();
camera.PictureCaptured += new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
void camera_PictureCaptured(Camera sender, GT.Picture picture)
Debug.Print("Picture Captured");
You have to make sure that camera is connected/ready first. Check this tutorial, it shows how to do that:
Thank you.
I change the code and use external power.
but the connected event not fired.
Output is
Program Started
camera.CameraConnected += new Camera.CameraConnectedEventHandler(camera_CameraConnected);
camera.PictureCaptured+=new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
void camera_CameraConnected(Camera sender)
Ok. In that case first step would be to see if Camera shows up in Device Manager. You can connect it to your PC through the power module:
Check that first.
I have checked the link already and the camera is fine in my PC.
@ Tzu Hsuan - I see you had that issue before
http://www.tinyclr.com/forum/topic?id=5871&page=2
Did you get it working at that time? Is it the same camera module?
OK , stupid, I plug into wrong socket.
Its works now.
But do other test. some thing interesting.
I f i add the SD Card module and the camera in the same time, the camera do not work.
But after i remove the SD Card module the camera works well.
Whats wrong ?
@ Architect , I will check it next week then report here.
@ andre.m
The issue seems not be solved?
@ Architect: Add the external power , the same, camera not work with the SD card.
@ andre.m" Not works.
And even the camera.CameraReady shows true, the CameraConnected event not fire anymore.
Does GHI or anyone can test it for me? very strange.
By the way, I am using Spider.
bool ve = camera.CameraReady;
Debug.Print(ve.ToString());
Debug.Print("Carema test");
