camera.CameraConnected += new Camera.CameraConnectedEventHandler(camera_CameraConnected);
My project is a simple camera with a button, screen, camera, and an SD card reader. If I start the project with the card not inserted into the reader all is good, the CameraConnected event fires and calls my camera_CameraConnected handler. But if I start with the SD card inserted in the reader the CameraConnected event does not fire and my camera_CameraConnected handler is never called. Any ideas why?
Very unusual and I have never heard of something like that. Try to unplug other modules see if it makes a difference. Try running without debugger attached.
I think I can reproduce this error with very little code.
using GT = Gadgeteer;
namespace MinimalCameraConnectedError
public class Program : Gadgeteer.Program
Gadgeteer.Modules.GHIElectronics.Camera camera;
Gadgeteer.Modules.GHIElectronics.SDCard sdCard;
Mainboard = new GHIElectronics.Gadgeteer.FEZSpider();
Program program = new Program();
program.InitializeModules();
program.ProgramStarted();
program.Run();
private void InitializeModules()
camera = new GTM.GHIElectronics.Camera(3);
sdCard = new GTM.GHIElectronics.SDCard(5);
private void ProgramStarted()
private void camera_CameraConnected(Camera sender)
Debug.Print("Camera connected fired");
If there is no SD card in the slot when the above code runs I see the following lines in the output window:
But with an SD card in the slot at start-up all I see is:
My solution to this problem (bug?) is to abandon the CameraConnected event and use a timer instead:
program.Run();
var timer = new GT.Timer(100);
timer.Start();
if (camera.CameraReady)
timer.Stop();
initCamera();
private void initCamera()
Debug.Print("Camera now connected");
and with that code I see the output
regardless of whether the SD card is in the slot at start-up.
Iâm not sure a smaller card would help since I need the code to be robust for large cards. Do you have any thoughts about the Thread.Sleep in the GHI code?
Iâve now tried three SD cards, one 4GB, one 2GB, and one 128MB. They all cause the camera connected event to fail to fire. Would you like me to try anything smaller?
Yes please, down to 16 or 8mb of you can. No, of course Iâm joking.
So if you donât have the sd card in and you donât have camera connected, and start the app everything runs normally and inserting those in any order makes no difference? Can you tell us what camera you have?
Sorry Brett - what do you mean by âdonât have the camera connectedâ? The camera remains physically connected to slot 5 (as the code shows?) throughout the entire process. The camera is this one: http://www.ghielectronics.com/catalog/product/283 (from the FEZ Spider Starter Kit)
ok, itâs technically a USB camera, so I meant you could use it as a USB device and plug/unplug as needed. But in the case where youâre connecting it via a Gadgeteer cable (the usual way for this device, and the way you have it) you wouldnât want to disconnect it. So the question is, when you donât have SD card in and you run the app, then insert the SD card, do all the events fire as expected?
Further to this, why do you want a Camera Connected event ? If you think about it, itâs only meant to be fired when the camera is an actual USB device and gets connected. I note your timer is just waiting for camera to report ready, is there an equivalent connected property ?
Brett, you ask âthe question is, when you donât have SD card in and you run the app, then insert the SD card, do all the events fire as expectedâ. Let me quote my post at the start of this thread âIf I start the project with the card not inserted into the reader all is good, the CameraConnected event fires and calls my camera_CameraConnected handler. But if I start with the SD card inserted in the reader the CameraConnected event does not fire and my camera_CameraConnected handler is never calledâ I think that answers your question, doesnât it? Your other question is âwhy do you want a Camera Connected eventâ? It seems to be usual practise (for example in the tutorial code at GHI Electronics â Where Hardware Meets Software) to use the CameraConnectedEventHandler to delay any code that requires the camera until after the camera is initialized. As I point out earlier in this thread I can do that with a timer checking the CameraReady property but that feels a bit of a hack when GHI provide a CameraConnected event.
No Andre that is false. I am using the Visual Studio C# Express 2010 .Net Gadgeteer Application (NETMF 4.2) project template. For the code sample I posted I thought it would be useful to move all the code from the auto-generated partial class into one non-partial class so that I could post all the code. Sorry if thatâs confused things. This is a very very simple out-of-the-box Gadgeteer project, the simplest I could think of that still manifests the error.
Am I right in thinking that you guys do not see this error with this simple code? Or is the error reproducible for you too?
