Camera 1.1 module generates error
Greetings, I am new to .NET Gadgeteer and am having difficulty with the camera module. I purchased the FEZ SPIDER kit a couple of months ago, and just recently tried to follow the FEZ Spider starter guide, which walks through the setup of the boards and some sample software. Everything seems to work except when I click the button to take a picture, it throws a system argument exception the GHI.Hardware.dll.
I am using the latest download of the NETMF Gadgeteer Package 2014 R5 with the NETMF SDK version 4.3.2 GFE2 and the Gadgeteer SDK version 2.43.1000.
Any help or ideas that point me in the right direction are appreciated.
Thanks,
Charlie
Following is the output with the errors:
Create TS.
Loading start at a0e00000, end a0e2f494
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.6.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Camera (4.3.6.0) Attaching deployed file.
Assembly: GadgeteerCamera (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.DisplayTE35 (4.3.6.0) Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Button (4.3.6.0) Attaching deployed file.
Assembly: GHI.Usb (4.3.6.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZSpider (4.3.6.0) Resolving.
GC: 1msec 36444 bytes used, 7303224 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 7303224 bytes
Type 17 (ASSEMBLY ): 34584 bytes
Type 1E (BINARY_BLOB_HEAD ): 1332 bytes
Type 28 (MEMORY_STREAM_HEAD ): 36 bytes
Type 29 (MEMORY_STREAM_DATA ): 396 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Usb.dll’
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Camera\NETMF 4.3\le\GTM.GHIElectronics.Camera.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\DisplayTE35\NETMF 4.3\le\GTM.GHIElectronics.DisplayTE35.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Button\NETMF 4.3\le\GTM.GHIElectronics.Button.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZSpider\NETMF 4.3\le\GHIElectronics.Gadgeteer.FEZSpider.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.12.dll’ (Managed): Loaded ‘C:\Projects_Gadgeteer\GadgeteerCamera\GadgeteerCamera\bin\Debug\le\GadgeteerCamera.exe’, Symbols loaded.
Using mainboard GHI Electronics FEZ Spider version 1.0
Program Started
#### Exception System.ArgumentException - 0xfd000000 (5) ####
#### Message:
#### GHI.Utilities.Bitmaps::NativeConvertToFile [IP: 0000] ####
#### GHI.Utilities.Bitmaps::ConvertToFile [IP: 003e] ####
#### GHI.Utilities.Bitmaps::ConvertToFile [IP: 0021] ####
#### Gadgeteer.Modules.GHIElectronics.Camera::DoWork [IP: 007e] ####
A first chance exception of type ‘System.ArgumentException’ occurred in GHI.Hardware.dll
An unhandled exception of type ‘System.ArgumentException’ occurred in GHI.Hardware.dll
Uncaught exception
The thread ‘’ (0x5) has exited with code 0 (0x0).
welcome to forum.
check this thread. known issue
https://www.ghielectronics.com/community/forum/topic?id=17180&page=1
Thanks for the link to that thread. I didn’t realize that there were issues with the latest code and the camera module. Maybe I’ll wait a bit to see if the next release fixes this issue.
Does anyone have any idea when the next SDK version will be released?
Thanks for the help.
Charlie
@ cgage - We are actively working on it at the moment but we do not have a firm release date yet.
Thanks John. I appreciate the update.
