Calling on the community for offering a Low-cost wifi option
Not unless Gus tells me I should bother :slight_smile:
It is up to you but we are going to offer this module for sure. We are just making sure the design is flawless.
Hi Guys,
maybe this little ( 8mm x 8mm) wifi board is worth looking at.
It’s small, supports b/g/n, SSL, IPV6, AP, WPS, OTA FW and more … have a read.
If you look further through their products EC32Lxx range you’ll find something very interresting (thx to Valkyrie-MT pointing that out) it is partnered with an MCU you’ll probably know.
http://www.econais.com/products/wismart-modules
No hints on if thats weeks vs months away?
Interesting … not much hobbyist shopping available for these.
Only pricing for them I found was here (an Italian site): http://www.elettroshop.com/brands/eConais.html
yep, they are hard to find.
But that could be for the fact that they are just announced, early January 2014.
I’ve asked the European sales office in Greece and they, the sales office, responded they, the EC19Ds, will be on sale after February 15th. Hmm, next year is after feb. 15th as well … we’ll see …
$26.00 Low Power Wi-Fi RTX4100:
http://www.rtx.dk/Default.aspx?ID=3921
Features
Wi-Fi module w/ internal antenna
Ultra low power 802.11 b/g/n
Run application on module
Fast sleep to wake-up
FCC/IC/CE certified
Host is on-board (no drivers needed)
Full BSP (RTOS and drivers)
Full IPv4 and IPv6 stack
WEP, WPA, WPA2, WPS support
Reference applications: Web server, TCP/UDP Server/Client etc.
Libraries for easy connection to internet and cloud services
RTX application framework
Interface options: UART, SPI, I2S
Multiple sensor inferfaces and ADC/DAC port
Tiny: only 18mm x 30mm, including built-in Antenna
Software Support
Memory space for embedded user applications
Antenna on-board
Less than 4μA with OS running in low energy mode
5-600uA typical values (depending on QoS)
Low Power Wi-Fi module. Qualcomm / Atheros RF SoC with Energy Micro MCU, Built-In Antenna:
http://www.semiconductorstore.com/cart/pc/viewPrd.asp?idproduct=47831
Thanks for sharing (spam or not)
@ Sambo
Awesome find. The EFM32 is a very energy efficient chip.
IoT seems closer now - $26 in singles - cool.
Hi guys, I have a situation here.
As we know, CC3000 module is not on sale yet, so I made my own one for testing proposes. Is important to say that it works great with cerbuino bee (using the libraries in this post).
Problem: when I plug the module in the sockets 3 or 11 (s type) of my brand new Raptor, makes the Raptor boot as a GPS. Like when we have to initialize mainboards in boot-mode. I am working on socket 1. I cant make it work, but at least it boots as a Raptor.
I just realized that I can’t solve my issue alone.
I’m getting 040404 or 010101, like a clock. Previous in this post, Valkire had the same problem, but I don’t find a solution for it.
As this issue appears only for Raptor (works fine with cerbuino) I added the recommended resistors, I “pull-uped” MISO trying to make Raptor similar to cerbuino. Nothing works.
Now the cc3000 module works better on cerbuino but still failing on Raptor.
If someone solved this problem, please let me know how.
Thanks again.
@ crespi, you should start a new thread with this specific issue. It’s hard reading through all these post to piecemeal together an answer.
You’re right.
Thanks Mr. Smith 8)
I love competition, don’t you too?
I found a new one (FCC and CE approved!):
Embedded WiFi Module - 802.11 b/g/n Industrial Temperature HF-A11 for $18.20
The HF-A11 can operate in Infrastructure Station (STA) mode, Soft Access Point (AP) mode or AP+STA mode. Support for Router/Bridge mode networking is also provided.
Cheers!
It’s certainly good to have hardware choices. It is difficult though to assess the firmware quality of such modules (CC3000 was a reminder of this fact), and even with good hardware and firmware, we still need a high-quality NETMF driver for it. That’s where the real challenge lies, and the blood, sweat and tears.
@ Cuno - Yeh, you’re right. But we’ve got to start from somewhere in order to bring the cost of IoT connectivity down. Cost of WiFi add-on >= $70 is way too much!
I also believe that Ti is on the right track w/ their new CC3100/CC3200 series.
Around here, we like big 400 MHz processors, large touch screens, and extra CPUs for everything. A power-hungry WiFi option fits right in :wink:
@ andre.m - Power consumption is usually tied to output power. Check the specs, probably one has more transmit power (in dB or mW) than the other. So low current is not always better, depending on the range you want to cover with these WiFi modules.
If power hungry is what you want - IoT Labs has what you need! I don’t know the total, but the Bluegiga module requires a stable 450mA.
i am will ,sales in high flying.
Probably there is someplace need to be perfect. I think we are still able to support customer. SPI function is reserved, customer need to develop it based on the SDK.SDK can be download from our web. The default interface is UART.
any questions, feel free to contact me.
email :will_wen@ hi-flying.com
