Hello I am a engineering student. I want to know about difference of TWO PROGRAMMING LANGUAGE C AND C++ . In first semester I studied C and now I have to study C++ . I want to know which one of those two is tough one. Are those inter-related in Any ways ?
Life ahead easy or difficult for me ?
The answers are here:
C++ is the object orientated extensions to C.
Ok .At least you didnât call it Spam this time.
But given weâre probably 90% using C#, itâs not really a topic Iâd expect to be readily answered. Youâll get much more thorough answers to questions related to the .Net micro framework and C# than you will to general questions like this - just want you to know that how far you stray from those netmf topics will impact how your question is perceived and answered
I work with C++ and C# all the time. I donât mind answering C++ questions.
Point being is that itâs a byproduct of your experience, not the forumâs reason for existing, that you can assist. If you went to a C++ forum or coding site, youâd be more likely to have people who were there for the same reason to be able to assist. Same as if I asked about lawn mower engine repairs here, sure someone might be a mechanic and be able to answer me, but my chances of getting more relevant assistance is better if Iâm looking in a forum where mechanics hang outâŚ
@ Brett - I understood your point and agree. only the OP can answer why he is posting here.
btw, whatâs wrong with your lawn mower?
Get some sheep, no carburetors to fiddle with.
See, I donât know what the problem is, because I donât know anything about engines ! Can anyone help? [/joking]
The dogs would eat the sheep - perhaps I just need to teach them to eat the grass
@ Brett - the first thing I would check is whether you have the latest firmware installed on your mower
Iâm still erring towards power - maybe my USB port and cable is not able to deliver the power I need.
@ Brett - Is your mower USB2 or USB3?
I think itâs USB2, because itâs red not blue? And yes, I read the data sheet on the mower but couldnât find any USB compatibility mentioned. Maybe I did have a boy look at the data sheet, but Iâd like to think Iâd see something as obvious as USB in the index !
@ Brett
Your question is missing one or more of these details:[ul]
The name of the product.
The code youâre trying to run.
Details on your setup.[/ul]
(Generated by QuickReply)
Also, have you tried a different Gadgeteer socket and/or cable?
Honda Buffalo Buck HRU19.
Not trying to run code, just trying to get it powered properly. And I canât use different Gadgeteer cables because it doesnât look like itâs a Gadgeteer mainboard.
My house is on a 709m^2 block of land that has an area of 120m^2 of grass that requires mowing. I canât find where to plug the USB cable to get enough power and length to mow.
OK probably far enough with the lawn mower motor gag
