i am new in this Forum and this is my first thread.
I have a problem with the deboucing of standart button module.
At first, here is my code:
bool saveMode = false;
button.ButtonPressed += new Button.ButtonEventHandler(button_ButtonPressed);
void button_ButtonPressed(Button sender, Button.ButtonState state)
if (state == Button.ButtonState.Pressed)
Debug.Print("My Button is pressed");
DoIt();
Debug.Print("My Button is not pressed");
void DoIt()
if (saveMode == false)
Debug.Print("On");
saveMode = true;
button.TurnLEDOn();
if (saveMode == true)
Debug.Print("Off");
saveMode = false;
button.TurnLEDOff();
Output:
The buttonPressed method set directly the saveMode on and off with one press, but actually, it should be this:
press: Save Mode on
press: Save Mode off
I believe that it is up to the debouncing, but how can I avoid or resolv it?
I want save mensure ( potentiometer modul ) into a textfile on sd card.
The read mensured data any 100ms.
It is no problem to set the saveMode on and it is no problem to save my data into the textfile,
but if i want to set the saveMode off, the pressed button (module) dont respond to my buttonPressed code.
But if he responds, it will switch the save mode directly on, off, on, and never off.
SDCard c_SDCard;
string s_DateTime;
GT.Timer timer;
double voltage = 0;
static string _dataFilePath = @ "\test.txt";
// timer for mensure (100 ms)
timer = new GT.Timer(100);
timer.Start();
button2.ButtonPressed += new Button.ButtonEventHandler(button2_ButtonPressed);
sdCard.SDCardMounted += new GTM.GHIElectronics.SDCard.SDCardMountedEventHandler(sdCard_SDCardMounted);
sdCard.SDCardUnmounted += new GTM.GHIElectronics.SDCard.SDCardUnmountedEventHandler(sdCard_SDCardUnmounted);
// new object of class SDCard
c_SDCard = new SDCard(sdCard);
//set Storage Device in class SDCard
if (sdCard.IsCardMounted)
c_SDCard.SetStorageDevice(sdCard.GetStorageDevice());
void button2_ButtonPressed(Button sender, Button.ButtonState state)
if (sdCard.IsCardMounted && sdCard.IsCardInserted)
//set saveMode on when button is pressed and saveMode = false
saveMode = true;
button2.TurnLEDOn();
Debug.Print("SaveMode auf on geschaltet");
else if (saveMode == true)
//set saveMode off when button is pressed and saveMode = true
saveMode = false;
button2.TurnLEDOff();
Debug.Print("SaveMode wird off geschaltet");
void sdCard_SDCardUnmounted(GTM.GHIElectronics.SDCard sender)
Debug.Print("SD Card unmounted.");
c_SDCard.SetStorageDevice(null);
void sdCard_SDCardMounted(GTM.GHIElectronics.SDCard sender, GT.StorageDevice SDCard)
Debug.Print("SD Card mounted.");
//read input data (mensure)
voltage = potentiometer.ReadPotentiometerVoltage();
//save mensure, time to sd-Card
s_DateTime = DateTime.Now.ToString("HH:mm:ss,ff");
c_SDCard.StoreResult(voltage, s_DateTime, _dataFilePath);
And here the class which i use to handle sd-card methods:
I use the FEZ Spider Board with the 4.1 Framework.
Ok, i tried your proposal, its the same.
And without saving on sdcard, its the same too.
Can it be that I would have to press the button in 100ms to make it work? Its not possible. 1000ms are ok, but not 100
cache the read results, put the results in an array. Once that array is full (of say 16 or 32 reads), or you otherwise want to terminate then write it to sd card.
sorry, then you’re going to have to show us your code. Sounds like a code problem.
Do you really need to save 10 samples a second of analog input? Can you describe the reason you want to do this? Hope you realise that these are not precision ADCs you’re using, and there’s nothing that says the changes you see in between readings in that 100ms are actually accurate changes.
You’re also talking about needing some specific timing requirements. The #1 thing you should take away from this conversation is that NETMF is not real time and you can’t guarantee anything timing-wise. The garbage collector will kick in when it wants and it’ll take a chunk of time you can’t control (except by writing efficient code that doesn’t let the GC clean up after it). If you think you have challenges now, perhaps you’d best tell us more about your full requirements to make sure you’re not headed for a disaster.
