Hi!
I woud like to now if the Motor Driver L298 Module can control a system like this: http://www.robotstore.it/product/279/Rover-5-Tank-Chassis-Cingolato-ad-Assetto-Variabile.html
Could anyone help me?
Thanks in advance.
Hi!
Thanks in advance.
Yes. The motor current rating seems compatible with board.
And there could be problems with the connectors?
The module does not use special connectors for the motor. There are screw terminals. If the motor comes with a connector, then all you have to do is remove them from the wires and connect to screw terminals.
Thank you very much, now it is all clear!
