Is brownout detection enabled on GHI mainboards? If so, is it configured to reset device on brownout event? I am particularly interested in G120 and G400.
Two suggestions:
Add a section on brownout topic in G120 and G400 user manuals explaining how it is configured to work
Add method(s) within GHI.Processor class that allows enabling/disabling and/or configuring brownout detection circuit
@ iamin - I do not believe we configure them beyond any defaults. You can always add an item to the task tracker if you want us to expose them in the libraries.
@ John - So this leads to another question - what are the default settings for brownout? For example, can you tell us how do you configure BORD, BOGD, BODRPM bits for G120?
@ iamin - I do not believe we set them at all. So whatever values they take at reset which are 0 according to the manual. You can use the register class to be sure.
@ Gene - I have not yet found a spare time to do some tests on this topic. But when do, I will start with G120. If you need immediate answer, I suggest asking GHI team.
