The BrainPad now has 2 standard options to program, make code and visual studio. We call those “start making” and “go beyond”. Both are great options and each served a defined purpose.
I know I know, when can we buy a BrainPad? We have made one final change to the reset circuitry. The production BrainPad now enters the loader mode by simply holding the reset button down for 3 seconds. This is being tested now and production starts right when or engineers give us the thumbs up.
In the code you have, it is checking if the button WAS pressed, and not IS pressed. They are currently two different blocks. The display currently still has an I2C issue, so you won’t see anything on the physical BrainPad screen yet.
Was is the semantics of “was pressed”? The software remembers that the button was pressed, even after released, and remains “was pressed” until it is was queried?
Was pressed detects when the button is pressed one time. It returns true only once. You will need to release the button and repress it to get “true” again.
