Reading the Light- and Temperature-Sensors was trivial.
For the Accelerometer there is an Arduino library at
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Adafruit_SSD1306.h"
//http://www.arduinolibraries.info/libraries/mma8453_n0m1
#include <MMA8453_n0m1.h>
/* ============== MAIN =====================*/
//Use I2C with OLED RESET pin on D13
#define OLED_RESET 13
Adafruit_SSD1306 oled(OLED_RESET);
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
uint32_t _BlueLED = PC6;
uint32_t _RedLED = PC9;
uint32_t _Button = PA5;
uint32_t buzzPin = PB8;
uint32_t LightSensor = PB1;
uint32_t TempSensor = PB0;
int reading;
char Buff[128];
int state = 0;
MMA8453_n0m1 accel;
void setup() {
Serial.begin(9600);
Serial.println("Hallo BrainPad");
oled.begin(SSD1306_SWITCHCAPVCC, 0x3C);
oled.display(); // show splashscreen
delay(2000);
oled.clearDisplay();
oled.display();
tone(buzzPin, 440, 500);
delay(500);
tone(buzzPin, 880, 500);
pinMode(_BlueLED, OUTPUT); // Blue
pinMode(_RedLED, OUTPUT); // Red
pinMode(_Button, INPUT_PULLUP);
oled.setTextSize(1);
oled.setTextColor(WHITE);
accel.setI2CAddr(0x1C); //evtl. change your device address if necessary, default is 0x1C
accel.dataMode(false, 2); //evtl. enable highRes 10bit, 2g range [2g,4g,8g]
void loop()
// Beep if Button U pressed
state = digitalRead(_Button);
if (state == LOW)
delay(500);
// toggle blue LED
if (digitalRead(_BlueLED))
{ digitalWrite(_BlueLED, LOW); }
{ digitalWrite(_BlueLED, HIGH); }
oled.display();
// Get and write light intensity
reading = analogRead(LightSensor);
int lightLevel = map(reading, 0, 1023, 0, 100);
sprintf(Buff,"Light: %d", lightLevel);
printLine(0, Buff);
Serial.println(Buff);
// Get and write temperature
reading = analogRead(TempSensor);
// The scaling is probably not correct
float tempLevel = (reading - 135) / 6.25;
int prePoint = (int)(tempLevel / 1);
int postPoint = (int)(((tempLevel - prePoint) * 100) / 1);
sprintf(Buff,"Temp: %d.%d", prePoint, postPoint);
printLine(1, Buff);
// Get and write Accelerometer values
accel.update();
int accel_X = accel.x();
int accel_Y = accel.y();
int accel_Z = accel.z();
sprintf(Buff,"X: %d Y: %d Z: %d", accel_X, accel_Y, accel_Z);
printLine(2, Buff);
oled.display();
delay(2000);
void printLine(int line, const char* stringToWrite )
oled.setCursor(0, line * 8);
oled.println(stringToWrite);
oled.display();
