Originally published at: BrainClip Video Series – BrainPad
This video series provides detailed step-by-step instructions for wiring and coding using the BrainPad Pulse & MakeCode
Distance Sensor
Use a Distance Sensors to virtually see the world around you detect distance and avoid objects.
RGB LED
Use the RGB LED module’s red, green, and blue elements to create a variety of different colors.
LED Ring
The LED Ring module uses smart LEDs that can be used to make lights dance and even create interactive arcade type games.
Rocker Module
A Rocker Module can be used to create an external analog joystick for moving objects on the BrainPad Pulse screen.
IR Remote
Adding a remote control to the BrainPad Pulse is easy with the IR module. All the buttons can be programmed to do just about anything you can think of.
