I have the memory “split” to allow & use a bootloader to update my app. Normally this bootloader is not called by the main app (unless I’m doing a rare update).
However, it seems that when power is applied, the board (EMX/cobra) always takes twice as long as it used to to boot up into the normal app…is this true? can it be prevented?
I did use: SystemUpdate.EnableBootloader(); , though the bootloader code itself is not being called (except in the rare cases when I do an update).
Should it normally be disabled? would that effect the power-up time?
I see this option (I have NOT touched it or used it)…is it the cause of the slowdown: SystemUpdate…::…AlwaysRunBootloader Method
The managed bootloader mode will be forced upon power up (when power completely disconnected and then connected again). Note that future reboots activate the normal modes.
I have heard that relaease 4.2 is faster in booting, but I’m not ready to move to that yet. Would this also have the same issue?
Hoyt
