I’m using the UC5550 with UCM and UD700. Am I right in assuming that the Boot x can be used as GPIO after boot ?
Yes they can be.
Side note, if you are working on a design you should discuss SITCore with our team ASAP. I know you are an insider but this not is for other readers
Already using SITCore (insider) I assume LDR, APP, and Mode are the same on 20260
If a pin has GPIO feature then yes it can…and they do.
Are schematics available for SoM 20260 and the dev board ?
Fight Club territory!
Are we starting to talk about insider stuff in the open?
Everything will be shared at the right time.
