So is the solution to switch to a processor with native parallel graphics or use basicgraphics?
Where would I find documentation on what is/is not implemented on each processor?
My plan is to use several different processors with identical class implements.
Sorry, new to this product line (<10hrs). Aside from a small bump with graphics, this is awesome!!!
The documentation is at https://docs.ghielectronics.com. You should go through all of the hardware and software sections. I like to skim through all of the documentation so later, when I have a question, I remember seeing something and can go look for it.
Yes, when the native graphics are not available, then you can use basic graphics.
All of the library software is available on https://github.com. If something is missing, I usually go to the library code and see if the function has been entirely implement in managed code(c#). Then I can steal, I mean borrow, the code. Search for “tinyclr libraries”
