Hi all, I have a problem, how can I synchronize two methods?
Example:
In the main program I have a timer that elapsed any 50ms generates an event, in this event send a stream byte in the serial!
And I have 2 button, 1 button send another code in the serial and the 2 button send another code in the serial:
private void timer1_Tick(object sender, EventArgs e) //50ms
_serial.send(comand.get);
private void button1_Click_1(object sender, EventArgs e)
_serial.send(comando.start);
private void button2_Click_1(object sender, EventArgs e)
_serial.send(comando.stop);
In the code of class serialport, the method send, send in the serial the relative command
class serial
public void send(object command1)
switch (command1)
case comando.start:
buffertx[0] = (byte)'s';
_SerialPort.Write(buffertx, 0, 1);
break;
case comando.stop:
buffertx[0] = (byte)'S';
break;
case comando.get:
buffertx[0] = (byte)'U';
break;
Now work, but the problem is the serial receive:
I want to synchronize the method send with the method event serial data receive :
when I send a command, I have to wait for a response before sending another command
