Best way to convert an integer to hexadecimal string?
Hi,im trying to perform a function to make a convertion like .ToString(“X”)
I need to convert a int value like 1023 to its hex representation but in a string format like this: “3FF”.
now looking in fezzer.com i found a function that converts a byte to a hex string but i need more range and no only the top 255 (FF).
i’m using a panda, and the sdk 4.1 :slight_smile:
Use the fezzer code and just shift as you need greater range.
[url]http://www.fezzer.com/project/84/convert-byte-to-hex-string/[/url]
For instance mask with 0xF000 >> 12 gives you an index into the hex string that represents the highest order 4 bits; 0xF00 >> 8 gives next 4, and so on
thanks for your help.
i modified the function adding an extra range and works fine ;D.
here is the final function.
public string Byte_ToHex(int number)
            string hex = "0123456789ABCDEF";
            return new string(new char[] { hex[(number & 0xF000) >> 12], hex[(number & 0xF00) >> 8], hex[(number & 0xF0) >> 4], hex[number & 0x0F] });
also i put this topic in fezzer.com so it can be useful to someone else 8)
Here is the link :slight_smile:
http://www.fezzer.com/project/258/int-to-hex-conversion-with-extended-range/
I have added this before, but I rather like this function from Jens Kuhner’s book
public static string ByteToHex(byte b)
            const string hex = "0123456789ABCDEF";
            int lowNibble = b & 0x0F;
            int highNibble = (b & 0xF0) >> 4;
            string s = new string(new char[] { hex[highNibble], hex[lowNibble] });
            return s;
Below is a little code to make it an extension method, so you can use it like this:
byte b = 42;
b.ToHexString();
namespace TestProgram
  public static class Extensions
    public static string ToHexString(this byte b)
      return s;
    public static string ToHexString(this int i)
      int nibble0 = i & 0x000F;
      int nibble1 = (i & 0x00F0) >> 4;
      int nibble2 = (i & 0x0F00) >> 8;
      int nibble3 = (i & 0xF000) >> 12;
      string s = new string(new char[] { hex[nibble3], hex[nibble2],
                                         hex[nibble1], hex[nibble0] });
      return s;
namespace System.Runtime.CompilerServices
  public class ExtensionAttribute : Attribute { }
  1. ok, i think yours can be a more useful way to make the conversion. thanks ;D
