I received my new BeagleBone Black Wireless.
I set it down on something conductive (I would assume…)
Now when I plug in USB or 5 Volt power the Power LED blinks once! Grrrrrrr :-[
@ cyberh0me - DoA is not the same as “set down on something constructive”
@ Gus -
“set down on something constructive” <- Then it would work again!
Where do I get one of those?
Probably my fault but I do not know how I did it. Could it be because my work area if full of junk?
@ willgeorge - There are certain pins on the Beagle Bone Black that if you short will destroy the device. Was the device on when you set it down?
@ Mr. John Smith -
I really do not know how it happened. I had a small metal tweezer on the desk so maybe I set the board on it.
It was working, I had to do other things and left the room for awhile and when I came back it was not working.
Maybe one of the cats was up on the table or more likely I did it without knowing I did.
Some things are probably best not written down in public if you don’t know for sure and an RMA is an option
@ ianlee74 -
Not sure I understand the meaning…
I have no Ax to Grind toward anyone or product.
To me a RMA is not an option. I wrote it off as a learning experience.
@ willgeorge - Don’t forget to salvage connectors and the like from it.
Sorry, I wasn’t suggesting you have an ax to grind but only that it could be that you have a legitimate RMA. I’ve had several products in the past that might fire up once or twice then never again. So, maybe not technically a DOA but still very much faulty due to a part part that let out the smoke much sooner than it should have. I was only suggesting that if I’m uncertain of the cause of a failure, I typically would discuss it directly with the manufacturer first before laying blame on myself or them. You very well could end up with a good board out of the call. You never know, this could be a problem lots of folks had out of that batch.
This made me LOL.
It’s a disease!
“Oh, my point and shoot camera got destroyed when my water bottle opened in my backpack. Oh well, at least I will have an afternoon of unscrewing very tiny screws, and looting the camera’s corpse for tiny servos for the zoom lens, cool little plastic lenses , an lcd screen, and of course, the tiny screws themselves”
@ mtylerjr - Of course the tiny screws themselves
