BDESC-S10E-RTR Electronic Speed Control hook up to Cerbuino Bee
Have you connected the SC ground wire as well?
With rc speed controllers you will need to arm it before it will run. So find the data sheet and see what sequence it needs. You will need to do something like drive it low then high then low to program its range.
