I like to connect a batteryholder to the FEZ mini board (not starterkit). How can this be achieved. Should there be additional components added?
Roel
Roel
You will need to connect the wire from battery holder to the pins on mini. By soldering them or by using a female header (which needs soldering too)
Or use FEZ Mini in the way it meant to be used, on a bread board.
You could also get an adapter like this: 9V battery holder with switch & 5.5mm/2.1mm plug : ID 67 : $3.95 : Adafruit Industries, Unique & fun DIY electronics and kits
