I could connect and send telemetry via IOT Hub, but the recieving method doesn’t work. Do I have to edit anything on the script? I see in the VSC monitor that the message arrived there.
solved solved
If you manage to solve your own problem, it’s awesome if you share the solution. This way, others who might run into the same issue in the future can benefit from your wisdom and learn from your experience.
There is no need to subscribe to the D2C topic, and also if you recieve from VSC portal the messsages won’t appear in tinyclr (prolly the portal catches them before)
