Following the GHI AWS Example
This is my ARN with the Customer ID replaced
var iotArnString = "arn:aws:iot:us-east-1:000000000000:thing/Device1";
var iotPort = 8883;
var deviceId = "Device1";
I get an exception on connect
var connectCode = iotClient.Connect(connectSetting);
Exception System.InvalidOperationException - CLR_E_INVALID_OPERATION (1)
#### Message:
#### GHIElectronics.TinyCLR.Devices.Network.Provider.NetworkControllerApiWrapper::GetHostByName [IP: 0000] ####
#### System.Net.Dns::GetHostEntry [IP: 000b] ####
#### GHIElectronics.TinyCLR.Networking.Mqtt.MqttStream::.ctor [IP: 000d] ####
#### GHIElectronics.TinyCLR.Networking.Mqtt.Mqtt::.ctor [IP: 005e] ####
#### AWSTest.Program::DoTestAwsMqtt [IP: 0098] ####
#### AWSTest.Program::Main [IP: 000c] ####
Exception thrown: âSystem.InvalidOperationExceptionâ in GHIElectronics.TinyCLR.Devices.Network.dll
An unhandled exception of type âSystem.InvalidOperationExceptionâ occurred in GHIElectronics.TinyCLR.Devices.Network.dll
Anyone run into this ?
can you please try catch that exception?
static void DoTestAwsMqtt()
var iotArnString = âarn:aws:iot:us-east-1:000000000000:thing/Device1â;
var iotPort = 8883;
var deviceId = âDevice1â;
var topicShadowUpdate = string.Format("$aws/things/{0}/shadow/update", deviceId);
var topicShadowGet = string.Format("$aws/things/{0}/shadow/get", deviceId);
var message = "{\"state\":{\"desired\":{\"My message\":\"From my test \"}}}";
var caCertSource = UTF8Encoding.UTF8.GetBytes(@"...");
var clientCertSource = UTF8Encoding.UTF8.GetBytes(@"...");
var privateKeyData = UTF8Encoding.UTF8.GetBytes(@"...");
X509Certificate CaCert = new X509Certificate(caCertSource);
X509Certificate ClientCert = new X509Certificate(clientCertSource);
ClientCert.PrivateKey = privateKeyData;
var clientSetting = new MqttClientSetting
BrokerName = iotArnString,
BrokerPort = iotPort,
CaCertificate = CaCert,
ClientCertificate = ClientCert,
SslProtocol = System.Security.Authentication.SslProtocols.Tls12
Mqtt iotClient = null;
try
iotClient = new Mqtt(clientSetting);
iotClient.PublishReceivedChanged += (a, b) =>
Debug.WriteLine("Received message: " + Encoding.UTF8.GetString(b.Data));
iotClient.SubscribedChanged += (a, b) => { Debug.WriteLine("Subscribed"); };
var connectSetting = new MqttConnectionSetting
ClientId = deviceId,
UserName = null,
Password = null
ushort packetId = 1;
iotClient.Subscribe(new string[] { topicShadowGet }, new QoSLevel[]
{ QoSLevel.LeastOnce }, packetId++);
iotClient.Publish(topicShadowUpdate, Encoding.UTF8.GetBytes(message),
QoSLevel.MostOnce, false, packetId++);
catch (Exception e)
Debug.WriteLine(e.Message);
Your string
look weird to me. I donât think it inclucde â:thing/Device1â.
The string should have âxxxxxxxxxxxxxxxxxxxxxxxxxxxx.amazonaws.comâ;
Thanks Dat - I have connected now.
I will push some tweaks to the document, once I am done.
Hello, Iâm also exploring the GHI AWS example and got the basic functions working on the SC20260 Board.
How far did you come?
To test all the functions I would like to have a AWS MQTT Client as a Windows PC Program but yet couldnât find a suitable Application (couldnât manage to connect to the AWS IoT-Service).
Can anyone give a recommendation and perhaps help how to handle the certificates?
MQTT.fx is a good tool for testing
http://mqttfx.jensd.de/index.php
Thank you. Can you please give me an advice, which certificates I have to use and where they must be selected in the different options of mqtt.fx?
I did start to write a complete document on this, unfortunately I have been occupied in supporting our teams to continue to deliver work over the COVID lockdown. Will attempt over the week.
For now
Select âSelf signed certificatesâ
CA File - VeriSign-Class 3-Public-Primary-Certification-Authority-G5.pem file (download from AWS)
Client Certificate File - Your device certificate.pem.crt from AWS
Client Key File - Your device private.pem.key from AWS
Thanks @Designer . I finally got the connection to the AWS IoT broker using the PC Application MQTT.fx (changed url like: a5u5zbsapbo9mi-ats.iot.eu-central-1.amazonaws.com ) with the following settings:
CA File - AmazonRootCA1.crt
Client Certificate File - My device certificate.pem.crt like: c4c37b4fbe-certificate.pem.crt
The device key that I got from AWS (like: c4c37b4fbe-private.pem.key) had to be converted to PKCS8 format using the openssl command:
openssl pkcs8 -topk8 -inform PEM -outform DER -in private_key_file -nocrypt > pkcs8_key
