I briefly see LOADING on the display , followed by the ASSERT message. It happens before the Main() function gets started, I put a breakpoint at the beginning of Main(). I show below the visual studio output window:
Found debugger!
Create TS.
Loading start at 202d5eb8, end 2030534c
Assembly: mscorlib (4.3.1.0) Assembly: Microsoft.SPOT.Native (4.3.1.0) Assembly: Microsoft.SPOT.Security.PKCS11 (4.3
.1.0) Assembly: System.Security (4.3.1.0) Assembly: Microsoft.SPOT.Hardware (4.3.1.0)
Assembly: Microsoft.SPOT.Graphics (4.3.1.0) Assembly: Microsoft.SPOT.TinyCore (4.3.1.0)
Assembly: Microsoft.SPOT.IO (4.3.1.0) Assembly: System.IO (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.Usb (4.3.1.0)
Assembly: Microsoft.SPOT.Hardware.SerialPort (4.3.1.0) Assembly: Microsoft.SPOT.Touch (4.3.1.0)
Assembly: Microsoft.SPOT.Ink (4.3.1.0) Assembly: Microsoft.SPOT.Hardware.PWM (4.3.1.0)
Attaching deployed file.
Assembly: Gadgeteer.WebServer (2.43.1.0) Attaching deployed file.
Assembly: DeviceHiveMF (1.2.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.RS232 (4.3.3.0) Attaching deployed file.
Assembly: TemperatureSensor (1.0.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: System.Xml (4.3.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.KeypadKP16 (4.3.3.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.Extender (4.3.3.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.SDCard (4.3.3.0) Attaching deployed file.
Assembly: TouchScreenInterface (1.0.0.0) Attaching deployed file.
Assembly: Configuration (1.0.0.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Net (4.3.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.EthernetENC28 (4.3.3.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Update (4.3.1.0) Attaching deployed file.
Assembly: System.Net.Security (4.3.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.DisplayT43 (4.3.3.0) Attaching deployed file.
Assembly: Microsoft.SPOT.Hardware.OneWire (4.3.1.0) Attaching deployed file.
Assembly: GHI.Pins (4.3.3.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.RS485 (4.3.3.0) Attaching deployed file.
Assembly: ProgrammableLogicControllers (1.0.0.0) Attaching deployed file.
Assembly: GHI.Networking (4.3.3.0) Attaching deployed file.
Assembly: GHI.Usb (4.3.3.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZCobraIINet (4.3.3.0) Attaching deployed file.
Assembly: Keyboards (1.0.0.0) Attaching deployed file.
Assembly: RFIDReaders (1.0.0.0) Attaching deployed file.
Assembly: GHI.Hardware (4.3.3.0) Attaching deployed file.
Assembly: Gadgeteer.SPI (2.43.1.0) Attaching deployed file.
Assembly: JsonSerializer (1.0.0.0) Attaching deployed file.
Assembly: HttpClient (1.0.0.0) Attaching deployed file.
Assembly: GHI.Glide (4.3.0.0) Attaching deployed file.
Assembly: SDCardReaders (1.0.0.0) Attaching deployed file.
Assembly: Logger (1.0.0.0) Attaching deployed file.
Assembly: System.Http (4.3.1.0) Attaching deployed file.
Assembly: Gadgeteer.Serial (2.43.1.0) Attaching deployed file.
Assembly: GHIElectronics.Gadgeteer.FEZRaptor (4.3.3.0) Attaching deployed file.
Assembly: SmartTruckRaptor (1.0.30.26162) Attaching deployed file.
Assembly: CWC.SmartKiosk.WebInterface (1.0.0.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.TempHumidity (4.3.3.0) Attaching deployed file.
Assembly: KioskUtility (1.0.0.0) Attaching deployed file.
Assembly: System (4.3.1.0) Attaching deployed file.
Assembly: SocketServer (1.0.0.0) Attaching deployed file.
Assembly: System.Text.RegularExpressions (4.3.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.RelayX1 (4.3.3.0) Attaching deployed file.
Assembly: Gadgeteer.WebClient (2.43.1.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.USBHost (4.3.3.0) Attaching deployed file.
Assembly: GTM.GHIElectronics.USBClientDP (4.3.3.0) Attaching deployed file.
Assembly: SmartView (1.0.0.0) Attaching deployed file.
Assembly: XGadgeteer.WebServer (2.43.0.0) Attaching deployed file.
Assembly: Gadgeteer (2.43.1.0) Attaching deployed file.
Assembly: Displays (1.0.0.0) Resolving.
GC: 1msec 1211148 bytes used, 65894616 bytes available
Type 0F (STRING ): 24 bytes
Type 15 (FREEBLOCK ): 65894616 bytes
Type 17 (ASSEMBLY ): 70068 bytes
Type 1E (BINARY_BLOB_HEAD ): 1140984 bytes
GC: performing heap compaction…
Ready.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\mscorlib.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Native.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Security.PKCS11.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Graphics.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.TinyCore.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.IO.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.Usb.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.SerialPort.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Touch.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Ink.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.PWM.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.WebServer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Net.Security.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Http.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\Logger\bin\Debug\le\Logger.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\DeviceHive\DeviceHiveMF\bin\Debug\le\DeviceHiveMF.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.Serial.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\RS232\NETMF 4.3\le\GTM.GHIElectronics.RS232.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Discontinued Gadgeteer Products SDK\Modules\TempHumidity\NETMF 4.3\le\GTM.GHIElectronics.TempHumidity.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Hardware.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Networking.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Usb.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Discontinued Gadgeteer Products SDK\Mainboards\FEZCobraIINet\NETMF 4.3\le\GHIElectronics.Gadgeteer.FEZCobraIINet.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Mainboards\FEZRaptor\NETMF 4.3\le\GHIElectronics.Gadgeteer.FEZRaptor.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\Utility\bin\Debug\le\KioskUtility.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\TemperatureSensor\bin\Debug\le\TemperatureSensor.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Xml.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Discontinued Gadgeteer Products SDK\Modules\KeypadKP16\NETMF 4.3\le\GTM.GHIElectronics.KeypadKP16.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\Extender\NETMF 4.3\le\GTM.GHIElectronics.Extender.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\SDCard\NETMF 4.3\le\GTM.GHIElectronics.SDCard.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Glide.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\WebInterface\bin\Debug\le..\XGadgeteer.WebServer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\Configuration\bin\Debug\le\Configuration.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\System.Text.RegularExpressions.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\WebInterface\bin\Debug\le\CWC.SmartKiosk.WebInterface.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\Keyboards\bin\Debug\le\Keyboards.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\DisplayT43\NETMF 4.3\le\GTM.GHIElectronics.DisplayT43.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\Displays\bin\Debug\le\Displays.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\SDCardReader\bin\Debug\le\SDCardReaders.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\TouchScreenInterface\bin\Debug\le\TouchScreenInterface.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.SPI.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\EthernetENC28\NETMF 4.3\le\GTM.GHIElectronics.EthernetENC28.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Update.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.3\Assemblies\le\Microsoft.SPOT.Hardware.OneWire.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI NETMF v4.3 SDK\Libraries\le\GHI.Pins.dll’
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\RS485\NETMF 4.3\le\GTM.GHIElectronics.RS485.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\ProgrammableLogicControllers\bin\Debug\le\ProgrammableLogicControllers.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\RFIDReaders\bin\Debug\le\RFIDReaders.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\DeviceHive\HttpClient\bin\Debug\le..\JsonSerializer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\DeviceHive\HttpClient\bin\Debug\le\HttpClient.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\SmartView\bin\Debug\le\SmartView.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\SocketServer\bin\Debug\le\SocketServer.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\USBHost\NETMF 4.3\le\GTM.GHIElectronics.USBHost.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\USBClientDP\NETMF 4.3\le\GTM.GHIElectronics.USBClientDP.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\GHI Electronics\GHI .NET Gadgeteer SDK\Modules\RelayX1\NETMF 4.3\le\GTM.GHIElectronics.RelayX1.dll’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\CwcProjects\SmartTruck_tools\SmartTruckRaptor\bin\Debug\le\SmartTruckRaptor.exe’, Symbols loaded.
‘Microsoft.SPOT.Debugger.CorDebug.dll’ (Managed): Loaded ‘C:\Program Files (x86)\Microsoft .NET Gadgeteer\Core\Assemblies.NET Micro Framework 4.3\le\Gadgeteer.WebClient.dll’, Symbols loaded.
Here are the modules I am using, from the Program.generated.cs:
private void InitializeModules() {
this.tempHumidity = new GTM.GHIElectronics.TempHumidity(2);
this.ethernetENC28 = new GTM.GHIElectronics.EthernetENC28(3);
this.extender = new GTM.GHIElectronics.Extender(5);
this.usbHost = new GTM.GHIElectronics.USBHost(7); //Lockup Testing
this.usbClientDP = new GTM.GHIElectronics.USBClientDP(8);
this.sdCard = new GTM.GHIElectronics.SDCard(9);
this.rs485 = new GTM.GHIElectronics.RS485(11);
this.relayX1 = new GTM.GHIElectronics.RelayX1(13);
this.displayT43 = new GTM.GHIElectronics.DisplayT43(15, 16, 17, 14); //Lockup Testing
this.keypadKP16 = new GTM.GHIElectronics.KeypadKP16(18);
this.rs232 = new GTM.GHIElectronics.RS232(12);
this.rs2322 = new GTM.GHIElectronics.RS232(1);
this.rs2323 = new GTM.GHIElectronics.RS232(10);
this.rs2324 = new GTM.GHIElectronics.RS232(4);
