I know my code works with the 4.1.3.0 code, and I know that there is generally a concept in .NET of “as long as the version is kinda the same, use that assembly”. For GHI assemblies what is the right guarantee of API compatibility? That is, can I just say Version=4.1.* and be done with it?
I thought there was a more compatible way to do it than “everyone who uses my code better have the same versions of the assemblies, even though I don’t use features in the newer versions.”
That is, anyone who gets my code that doesn’t have 4.1.5.0 (let’s say they have 4.1.3.0) has to update their GHI code/firmware (which is probably a good idea anyway) or delete and re-add the references in my library csproj to refer to their older 4.1.3.0 version, even though I don’t use any features specific to 4.1.5.0, and 4.1.3.0 would work fine.
If you don’t include the GHI assemblies files in your project (output folder), I think Visual Studio will automatically get them from GHI SDK.
Delete the output folder before trying the project on another computer or SDK. It should work…
The IDE resolves the right version, but I’m not sure how this would work if there were multiple frameworks installed, but I don’t think that’s the case with most people.
