I’m trying to donwload an assembly of 102 KB with to fez spider, i conclude that this is to big for gadgeteer becuase it hangs. is this true. Does gadgeteer limits the amount of data to downlaod ?
I tried it with a smaller assembly of 5KB and it downloaded this very fast.
I’ve found out while debugging if you pause and then click again on debugging. the assembly loads perfectly and the program continues.
I accidentally discovered this strange huh. Anyone had this issue before?
hello,
are you sure you are loading the .PE version of the assembly? remember you cannot load the dll file you must copy the .pe file and upload it to your server.
check out the WIKI here:
Next Double click on bin/Debug/le folder (le stands for little Endian) DO NOT Copy the file in bin/debug/be folder. that's (big Endian) image.
Now you should see a file called TestPlugin1.pe (If you can't see the file extension please turn them on. google on how to do it.)
Next Copy the TestPlugin1.pe file from "le" folder to the root of your SDCARD. This is the only file you will need and NOT THE .DLL or any other file.
I dont know about Don, but i do load pe, dont have sleep on thread, and still have problem. But workaround is delete and set breakpoint, for my case, i can live with that.
