I have Visual Studio 2010 and have installed .Net Micro Framework SDK 4.2 and the GHI Package v4.2. I have created a simple project with a Cobra II attached. The project fails due to missing assemblies.
The project just places a simple print to the output.
When I select the Cobra II it adds the assemblies … is there documentation for the assemblies? or can some explain what i need to do? When I try to type the missing assembly which is reported as missng. It does not appear in the drop down list
I am now trying to migrate from the Arduino to .Net and hope the learning curve is not too steep!
If you’ve created a new project, then you can add the references in the right pane by right clicking “references” and saying add references. All the references for the project type you have selected are listed, and you can find the GHI and other optional netmf ones there. You’ll get the hang of what ones you want to add pretty quickly, but if you use a Gadgeteer project you’ll get a lot of that added for you by the wizard.
Feel free to ask questions, plenty of people here were in your shoes and are happy to help out.
I should have told you that I had eventually found those … so I have a program running!
Many thanks to all … I would like to create a single board to replace my concept … if anyone has suggestions on how I can acheive this I would appreciate it … in the meantime I can now work through the tutorials.
It controls a process that conditions mushroom compost.
Basically Arduino Mega+EthernetShield+RTC&SD Shield
A 16 channels MUX and 4 channel DAC PCB which I etched, which was really painful but satisfying once it worked and a bunch of relays and signal conditioners. Inputs monitoring the process and outputs controlling the process… with datalogging to SQL db
I would like a single PCB and the power of the SOM probably the G400 with a touch screen. A lot to learn and do … any pointers are more than welcome!
I will work though the tutorials to get a basic understanding. Maybe you can help point me in the right dirction, for example … if I view the catalog and the cobra II … the example for the wifi, is missing some code … where can I look to learn what I need to do … when I first reviewed the FEZ Panda II I ran into this problem quite alot. Once I get a grip I will then ask questions, or maybe there are friends out there who have questions?
I’ve picked up the tutorial for connecting the TE35 to the cobra … copied the demo code in, added the references … however, I cannot find GHIElectronics.NETMF.Hardware in the list. The code is complaining about the resources and configuration references? I assume these are part of the missing reference GHIElectronics.NETMF.Hardware?
