What will happen if I do this? Will it copy each element one by one, or will it copy a chunk of memory from one place to another? In other words, what will be executed - [em]memmove[/em] or [em]for[/em] cycle?
Dim arr1(10), arr2(5) As Byte
Array.Copy(arr2, 0, arr1, 0, 6)
Source code:
if(arraySrc->SameHeader( *arrayDst ))
CLR_UINT8* dataSrc = arraySrc->GetFirstElement();
CLR_UINT8* dataDst = arrayDst->GetFirstElement();
CLR_UINT8 sizeElem = arraySrc->m_sizeOfElement;
dataSrc += indexSrc * sizeElem;
dataDst += indexDst * sizeElem;
if(!arraySrc->m_fReference)
memmove( dataDst, dataSrc, length * sizeElem );
CLR_RT_HeapBlock* ptrSrc = (CLR_RT_HeapBlock*)dataSrc;
CLR_RT_HeapBlock* ptrDst = (CLR_RT_HeapBlock*)dataDst;
int incr;
if(arraySrc == arrayDst && ptrSrc < ptrDst)
incr = -1;
ptrSrc += length-1;
ptrDst += length-1;
incr = 1;
for(int i=0; i<length; i++, ptrSrc += incr, ptrDst += incr)
TINYCLR_CHECK_HRESULT(ptrDst->Reassign( *ptrSrc ));
else if(arraySrc->m_fReference && arrayDst->m_fReference)
CLR_RT_TypeDescriptor descSrc;
CLR_RT_TypeDescriptor descDst;
CLR_RT_HeapBlock* ptrSrc = (CLR_RT_HeapBlock*)arraySrc->GetElement( indexSrc );
CLR_RT_HeapBlock* ptrDst = (CLR_RT_HeapBlock*)arrayDst->GetElement( indexDst );
TINYCLR_CHECK_HRESULT(descDst.InitializeFromObject( *arrayDst )); descDst.GetElementType( descDst );
for(int i=0; i<length; i++, ptrSrc++, ptrDst++)
if(ptrSrc->DataType() == DATATYPE_OBJECT && ptrSrc->Dereference() == NULL)
TINYCLR_CHECK_HRESULT(descSrc.InitializeFromObject( *ptrSrc ));
if(CLR_RT_ExecutionEngine::IsInstanceOf( descSrc, descDst ) == false)
TINYCLR_SET_AND_LEAVE(CLR_E_INVALID_CAST);
CLR_RT_HeapBlock ref;
CLR_RT_HeapBlock elem; elem.SetObjectReference( NULL );
CLR_RT_ProtectFromGC gc( elem );
for(int i=0; i<length; i++)
ref.InitializeArrayReferenceDirect( *arraySrc, indexSrc++ ); TINYCLR_CHECK_HRESULT(elem.LoadFromReference( ref ));
if(elem.DataType() == DATATYPE_OBJECT && elem.Dereference() == NULL)
TINYCLR_CHECK_HRESULT(descSrc.InitializeFromObject( elem ));
ref.InitializeArrayReferenceDirect( *arrayDst, indexDst++ ); TINYCLR_CHECK_HRESULT(elem.StoreToReference( ref, 0 ));
