I’ve been playing with a FEZ Bit (modifying the sample application,) and just got in some custom PCBs using the SCM20100E SOM. I’m now trying to port my code over–and am encountering the following error when it’s trying to run:
The thread '<No Name>' (0x2) has exited with code 0 (0x0). 139 Failed allocation for 1019 blocks, 16304 bytes Failed allocation for 1028 blocks, 16448 bytes #### Exception System.ArgumentException - 0xfd000000 (1) #### #### Message: #### System.Drawing.Internal.Bitmap::CreateInstantFromResources [IP: 0000] #### #### System.Reflection.MethodBase::Invoke [IP: 0000] #### #### System.Resources.ResourceManager::GetObject [IP: 0083] #### #### System.Resources.ResourceManager::GetObject [IP: 0007] #### #### GHIElectronics.TinyCLR.UI.Controls.Button::InitResource [IP: 0009] #### #### Demos.Icon::.ctor [IP: 0004] #### #### Demos.ApplicationWindow::.ctor [IP: 000c] #### #### Demos.EncoderWindow::.ctor [IP: 0010] #### #### Demos.Program::Main [IP: 01a0] #### Exception thrown: 'System.ArgumentException' in GHIElectronics.TinyCLR.Drawing.dll An unhandled exception of type 'System.ArgumentException' occurred in GHIElectronics.TinyCLR.Drawing.dll
I’m assuming there is some step I’m missing–I’m just not sure what it is. Any help would be appreciated.
