Your Pi Zero 2W, now in C#, Python and C++. Just press F5.
Endpoint for Raspberry Pi Zero 2W
No more SSH Plug in the USB cable, pick your board from the list and press F5. No keys, no passwords, no IP addresses. It’s the same flow we’ve had in TinyCLR for years, now on a Linux-class processor, and it works for all three languages.
Three languages, one set of APIs CAN, ADC, SPI and the rest work the same way from C and Python as they do from C#. Learn the API once and it goes with you to every language. There’s no C or C++ toolchain to install.
pip install over the debugger. Install Python packages onto the board from VS Code, over USB, from your PC. The board does not need an Internet connection.
