But at the same time, I want to be able to some of digital pins for other purpose. But when FEZ mini sits on the control board, according to documentation: [url]http://www.tinyclr.com/downloads/Mini/FEZ_Mini_RobotKit.pdf[/url]
[ol]Di3-Di5, used by Motor A
Di6-D9, used by Motor B
Di2 and Di4 used by Buttons[/ol]
So short question is… is there any 2 PWM pins available that I could use from this configuration, if not are there any way to work around?
If you are talking about connecting your Stampede to a OC driven pins, it’s not going to work. For one, the car’s drivers are all written.You need PWM pins.
[quote]If you are talking about connecting your Stampede to a OC driven pins, it’s not going to work. For one, the car’s drivers are all written.You need PWM pins.
[/quote]
Chris,
It works just fine, i used standard drive downloaded from FEZ.
