I can enable also this kind of boards for TinyCLR, but if there’s some interest out there…
Nucleo-144pin for STM32F767 use same chip used in UCM5550. Nucleo has no SDRAM and no QSPI Flash, no display anyway, although it is a very cheap board.
Is the Pope Catholic?
Maybe budist LOL
I am interested!
me, too
There is some interest out there as well
It’s on github
Github
Note: I need to better setup pins for various peripherals. Next update I will include it for all the internal peripheral, i2c, spi, pwm and so on.
On Github there are updated files for nucleo-f767.
what about the mikromedia for stmf4/7 ?
MMB for F7 is on GitHub. MMB for F4 is under development … few days and I’ll update.
Hi, I am struggling to get your port to work. What bootloader did you use? I have tried the UC5550 but it does not show up on my computer, so I can’t download the firmware.
/BitMaestro
Hi @BitMaestro, for UC5550 use GHI bootloader and GHI ready firmware. My porting is for Nucleo F767 and Discovery-F769. For this board I don’t use any bootloader. The TinyCLR must be flashed using ST-LINK embedded on the boards.
Hi @dobova, thanks for your quick reply!
I’m also using the Nucleo F767, so that explains why it is not working. I will try with the ST-LINK…
Hi @dobova,
I get a build error when I try to build your latest code:
D:\Code\TinyCLR\TinyCLR_Port\Build\release\NUCLEO-F767\STM32F7_Startup.obj: In function SystemInit': STM32F7_Startup.cpp:(SectionForBootstrapOperations+0x110): undefined reference toSTM32F7_Startup_MpuConfiguration()’
Have you file stm32f7_mpu.cpp in the target\stm32f7xx directory?
Yes, but the closest function match there is:
void STM32F7_Mpu_Configuration(uint32_t address, STM32F7_Mpu_RegionSize mpuRegionSize, STM32F7_Mpu_RegionNumber mpuRegionNumber, bool doCache)
I found the method in Devices\DISCO-F769NI\Device.cpp. Could I copy that to the Device.cpp file for the Nucleo-F767?
Let me check, probably my device.cpp for nucleo not yet updated on github.
Anyway just copy the function in your device.cpp and you solve the problem.
@BitMaestro I confirm that I didn’t push modification to github, now it is updated.
