I have a TE35, Accel G248, Gyro, Compass and try to connect them all to the FEZ Spider. Any easy way to attach them since there aren’t enough ready to use I2C connections on the FEZ Spider? Thank you
I2C is just a bus so you could make a hub that breaks the required pins out to multiple modules or you could convert the driver to use our SoftwareI2C class on a Y socket.
Thank you very much!
