With the follow code I get the following error:
An unhandled exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.W5100.dll
Additional information: Currently, Connect() method is only for TCP socket use.
Any Ideas what I am doing wrong?
using System; //Needed to create Sockets
using System.Text;
using Microsoft.SPOT.Net; //Needed to create Sockets
using Microsoft.SPOT.Time;
using GHIElectronics.NETMF.Net.Sockets;
using GHIElectronics.NETMF.Net.NetworkInformation;
using Socket = GHIElectronics.NETMF.Net.Sockets.Socket;
namespace FEZ_Panda_II_Get_Time_From_TimeServer
const Int32 c_port = 80; // Port used for http requests
byte[] ip = { 192, 168, 0, 150 }; // Assigned IP address
byte[] subnet = { 255, 255, 255, 0 }; // Assigned Subnet
byte[] gateway = { 192, 168, 0, 1 }; // Assigned Gateway Address
byte[] mac = { 0x00, 0x9A, 0xD2, 0xC2, 0xD9, 0x2A }; //Randomly generated MAC from http://www.macvendorlookup.com
WIZnet_W5100.Enable(SPI.SPI_module.SPI1, (Cpu.Pin)FEZ_Pin.Digital.Di10, (Cpu.Pin)FEZ_Pin.Digital.Di9, true); // WIZnet interface with FEZ Connect
//NetworkInterface.EnableStaticIP(ip, subnet, gateway, mac); //Assigns ip/subnet/gateway/mac to Wiznet
//NetworkInterface.EnableStaticDns(new byte[] { 192, 168, 0, 1 }); //
//Socket server = new Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp);
IPEndPoint localEndPoint = new IPEndPoint(IPAddress.Any, c_port);
Dhcp.EnableDhcp(mac); //Used to check if there were any problems with the network settings
Debug.Print("Current Time: " + DateTime.Now.ToString());
Utility.SetLocalTime(NTPTime("time-a.nist.gov"));
Debug.Print("Updated Time: " + DateTime.Now.ToString());
Debug.GC(true); // Enable Garbage Collector
Debug.EnableGCMessages(true); // Enable / Disable Garbage Collector Messages
/// <summary>
/// Get DateTime from NTP Server
/// Based on:
/// http://weblogs.asp.net/mschwarz/archive/2008/03/09/wrong-datetime-on-net-micro-framework-devices.aspx
/// </summary>
/// <param name="TimeServer">Timeserver</param>
/// <returns>Local NTP Time</returns>
public static DateTime NTPTime(String TimeServer)
// Find endpoint for timeserver
IPEndPoint ep = new IPEndPoint(Dns.GetHostEntry(TimeServer).AddressList[0], 123);
// Connect to timeserver
Socket s = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
s.Connect(ep);
// Make send/receive buffer
byte[] ntpData = new byte[48];
Array.Clear(ntpData, 0, 48);
// Set protocol version
ntpData[0] = 0x1B;
// Send Request
s.Send(ntpData);
// Receive Time
s.Receive(ntpData);
byte offsetTransmitTime = 40;
ulong intpart = 0;
ulong fractpart = 0;
for (int i = 0; i <= 3; i++)
intpart = (intpart << 8) | ntpData[offsetTransmitTime + i];
for (int i = 4; i <= 7; i++)
fractpart = (fractpart << 8) | ntpData[offsetTransmitTime + i];
ulong milliseconds = (intpart * 1000 + (fractpart * 1000) / 0x100000000L);
s.Close();
TimeSpan timeSpan = TimeSpan.FromTicks((long)milliseconds * TimeSpan.TicksPerMillisecond);
DateTime dateTime = new DateTime(1900, 1, 1);
dateTime += timeSpan;
TimeSpan offsetAmount = TimeZone.CurrentTimeZone.GetUtcOffset(dateTime);
DateTime networkDateTime = (dateTime + offsetAmount);
return networkDateTime;
I hope your Panda arrives soon! I’m having a blast with the Tinkerer kit.
