Analog Pin Voltage
I see on the spec page that it says the analog pins are 3.3V but 5V tolerant. So can you actually use a 0 - 5v analog sensor, and set the scale to 5v in the code? Has anyone done this?
It is 5V tolerant as digital. Analog has to be 3.3V max.
You will need a voltage divider for 5v.
