I have a 5x5 keypad matrix that is scanned by setting the Columns high and then reading the Rows.
My problem is that on everything connected to Col 1 (An0) oscillates when it is read on any of the rows.
Is An0 different to the other pins when used as an output in some way?
I use the An pins as outputs because using An4 as digital input gives and argument exception when set as an InputPort.
OutputPort _C1 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.An0, false);
OutputPort _C2 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.An1, false);
OutputPort _C3 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.An2, false);
OutputPort _C4 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.An3, false);
OutputPort _C5 = new OutputPort((Cpu.Pin)FEZ_Pin.Digital.An4, false);
InputPort _R1 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.UEXT6, true, Port.ResistorMode.PullDown);
InputPort _R2 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.UEXT5, true, Port.ResistorMode.PullDown);
InputPort _R3 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.UEXT7, true, Port.ResistorMode.PullDown);
InputPort _R4 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.UEXT9, true, Port.ResistorMode.PullDown);
InputPort _R5 = new InputPort((Cpu.Pin)FEZ_Pin.Digital.UEXT10, true, Port.ResistorMode.PullDown);
Any ideas?
